Re: Damaged cylinder head repair
[Re: CSK]
#3082851
10/03/22 02:09 PM
10/03/22 02:09 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
As said EASY fix and by all means replace ALL the valves.
[Re: Al_Alguire]
#3082860
10/03/22 02:26 PM
10/03/22 02:26 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
As said EASY fix and by all means replace ALL the valves. Yes, after further thought , ALL of the valves not just the intake
[Re: CSK]
#3082863
10/03/22 02:33 PM
10/03/22 02:33 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Well, I see what’s 99% likely the cause of the failure. Yep, & replace ALL the intake valves, new springs & double check PV clearance My guess is, it’s the #1 reason for broken intake valves. On the plus side........ I’m liking the complete lack of carbon build up in that intake bowl.
[Re: fast68plymouth]
#3082895
10/03/22 02:59 PM
10/03/22 02:59 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Remember some broken pieces could have gone into other cylinders Even on the other side. My son had a 1/4 inch chunk of an Edelbrock intake valve in number three cylinder end up stuck in number 4 or 6 and pinch a ring.
#3083030
10/03/22 08:49 PM
10/03/22 08:49 PM
Posts: 3,105 Md.
carnut68
Md.
Well, I see what’s 99% likely the cause of the failure. Ok. Give me the good or bad news. The spring looks like new in that it was not moving around same for the keepers and retainer. No metal scuffing at all. I'm thinking the valve gave up. Or # 5 rod bearing went but it still had 60# oil pressure.
America First!
[Re: carnut68]
#3083053
10/03/22 10:08 PM
10/03/22 10:08 PM
Posts: 1,072 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Don't know what the top of the piston w/ the broken valve looks like, but I'd be looking very closely at all of the piston tops for any indications of other valves possibly coming into contact, too.
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3083060
10/03/22 10:28 PM
10/03/22 10:28 PM
Posts: 3,105 Md.
carnut68
Md.
Don't know what the top of the piston w/ the broken valve looks like, but I'd be looking very closely at all of the piston tops for any indications of other valves possibly coming into contact, too. It's bashed up and has a hole were the valve stem went thru it. The cylinder wall looks fine. #7 did,but when? Probably after #5 broke.
America First!
[Re: krautrock]
#3083177
10/04/22 10:24 AM
10/04/22 10:24 AM
fast68plymouth
So. Burlington, Vt.
I have some BBC heads here now that have a few valves showing the same thing.
There’s really only one way to get that shiny ring.
#3083179
10/04/22 10:35 AM
10/04/22 10:35 AM
Posts: 701 Lake Villa Il
INTMD8
Lake Villa Il
A very intimate relationship resulting in a shiny ring. Then everything crumbles after too much hitting and abuse. Sounds like a lifetime movie
[Re: INTMD8]
#3083183
10/04/22 10:46 AM
10/04/22 10:46 AM
fast68plymouth
So. Burlington, Vt.
The thing is, the fact that it’s showing contact for the full diameter means the valve is rotating, since nothing would touch all the way around otherwise.
So, the rotation means there is some degree of the stem flexing in different directions as the valve rotates around. Like bending a coat hanger back and forth......... it can only flex so many times before the material is fatigued and breaks.
In my mind, the question as to why the valve broke has been answered.
Also, the contact is not the result of valvetrain control problems. That’s not to say there couldn’t be some of that as well, but that won’t result in contact with an intake valve. When you float an intake valve, even if it’s lagging way behind the cam....... at IVC, the piston is nowhere near TDC. So, the only way to get the shiny ring on an intake valve is....... inadequate clearance during the IVO period.
It’s not all that uncommon for me to see this condition when I’m reconditioning heads.
[Re: carnut68]
#3083686
10/05/22 10:27 PM
10/05/22 10:27 PM
Posts: 3,105 Md.
carnut68
Md.
Any suggestions who to send the head to get it fixed?
America First!
[Re: carnut68]
#3083741
10/06/22 09:09 AM
10/06/22 09:09 AM
Posts: 13,182 aZLiViN
J_BODY
aZLiViN
Any suggestions who to send the head to get it fixed? Hopefully it’s a quality casting. I sent my leaky W5 head to a guy in Iowa that had brought sprint car heads back from the dead. My head basically crumbled as he tried to weld it.
[Re: carnut68]
#3083757
10/06/22 10:00 AM
10/06/22 10:00 AM
Brad_Haak
Loudoun County, VA
Any suggestions who to send the head to get it fixed? Indy would be my first call, considering they did lots of cylinder head repair work in the past. Whether the new owners do any of that, you'll only know by asking.
[Re: carnut68]
#3083901
10/06/22 07:49 PM
10/06/22 07:49 PM
Posts: 3,105 Md.
carnut68
Md.
It's an Indy head. So that's good to hear. Thanks.
America First!
[Re: pittsburghracer]
#3083926
10/06/22 09:25 PM
10/06/22 09:25 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You won’t know till it’s taken apart and stripped but I’m betting it’s fixable. Jump on it and get it to a shop before everyone else. Winters coming. Indy may even fix it.
Wow I suggested Indy 10-1-22. Lol 😂
#3083950
10/06/22 11:13 PM
10/06/22 11:13 PM
J_BODY
aZLiViN
Wow I suggested Indy 10-1-22. Lol 😂 We don’t listen to old guys! …..all kidding aside it’s a great time we live in when you can actually recommend Indy for something.
[Re: carnut68]
#3084164
10/07/22 10:33 PM
10/07/22 10:33 PM
Posts: 3,105 Md.
carnut68
Md.
What about Brett Miller? He's within reasonable driving distance.
America First!
