Re: Adding "grout" to a block
[Re: hemienvy]
#3082604
10/02/22 11:15 PM
10/02/22 11:15 PM
Posts: 43,115 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3082649
10/03/22 09:19 AM
10/03/22 09:19 AM
Posts: 4,457 Washington
madscientist
Washington
That’s the LAST place you want block filler. That’s where most of the heat is dumped from the piston though the rings. I think that’s a really bad idea.
[Re: hemienvy]
#3082675
10/03/22 10:45 AM
10/03/22 10:45 AM
Posts: 313 Northeast Indiana
73DAD
Northeast Indiana
I'm going to assume you have a block that has been heavily decked. Aftermarket blocks have very thick decks like you're trying to achieve, but they can get away with it because of cast iron's ability to transfer heat. Your typical block filler works much better as an insulator for heat transfer rather than a conductor. If you were trying to save a hemi block or something, maaaybe you could get away with molten aluminum poured in since it would be a little better for heat transfer, but I'd only want to try it on block that would be junk otherwise.
Disclaimer: I'm no expert, just speculating.
[Re: hemienvy]
#3082677
10/03/22 10:55 AM
10/03/22 10:55 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Not directly related to your question but...
If I remember correctly is the past we managed to split cylinder walls on stock small blocks that were grouted, one a half fill the other a full fill.
These were very high compression engines, I think one was 16-1 the other 15-1.
No problems with R blocks.
[Re: hemienvy]
#3083274
10/04/22 03:48 PM
10/04/22 03:48 PM
Posts: 11,521 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If I were going to do that, I would fill the whole thing. Not advisable for a gasoline powered, bracket application. I've filled them to the bottom of the water pump holes in the past.
It's a bandaid. Something else is going to move or break at some point. We're just trying to keep the cylinders round.
[Re: hemienvy]
#3085115
10/11/22 01:01 PM
10/11/22 01:01 PM
Posts: 4,036 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Has anyone ever turned the block upside down and grouted only the upper part of the cylinders ? Maybe 1 or 2 inches ?
You would have to use a block deck plate, then when finished drill through the grout for the coolant openings. As a39 Coronet said you can't redrill it in that way. and if you do fill it conventionally TOO HIGH, you'll block coolant flow thru the block at the blind headbolt bosses. Maybe that is what's been conveyed and understood in his reply?
