I'll never understand the attraction of lifting a 2 WD truck, but having said that no one I know makes a lift kit for them. You could put the early 90's diesel 1 ton springs in it though. That should give you a good inch and a half.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
