Re: Hemi piston ID
[Re: Cape]
#3082392
10/01/22 11:58 PM
10/01/22 11:58 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
Hey every! I’m trying to figure out what pistons I have in my Hemi. Sounds stupid as you’d think I would know after having the engine built. So they were suppose to be CP 12.5:1 pistons but I think the builder put the wrong ones in. I pulled the oil pan off to see if I could see a part number and all I found was the CP logo and 426H-C, I can’t find any info on these pistons. The motors a 4.28 bore and 4.15 stroke with a 6.86 rod. The motor made 827@8000 and didn’t really perform like it should have that’s why I pulled the pan, and I have a buddy with the same short block but with Ross 13.5:1 piston which is completely different. Any help would be appreciated 426 street hemiroid motors are hard to figure the correct compression ratio without knowing the exact deck height on the pistons above the deck, the dome volume, combustion chamber volume, head gasket volume and the bore and stroke. I would check the actual deck height at TDC first with one head off and then move the piston down to either zero deck height or maybe .500 below the deck surface and then seal the ring lands up to the cylinder walls with chassis grease and then find out what that actual volume is and then do the math on a flat top piston that far down and then due the math to get your dome volume and use that information to get the true compression ratio Don't be surprised if it is not exactly what the piston maker said they would be
Re: Hemi piston ID
[Re: A727Tflite]
#3082456
10/02/22 12:01 PM
10/02/22 12:01 PM
Posts: 213 Canada
Cape
Canada
Thanks for the suggestion. I don’t have the motor out yet, in a couple weeks it’ll be out so I’ll so I’ll get a better chance to look at it. Does anybody know if the number 426H-C on the underside of the piston mean anything? I can’t get to the top of the piston until I get the heads off.
Re: Hemi piston ID
[Re: Cape]
#3082458
10/02/22 12:06 PM
10/02/22 12:06 PM
Posts: 3,069 Michigan
A727Tflite
Thanks for the suggestion. I don’t have the motor out yet, in a couple weeks it’ll be out so I’ll so I’ll get a better chance to look at it. Personally I am still confused. You said it’s not performing like it should. 800+ horsepower and it’s not performing like it should?
Re: Hemi piston ID
[Re: Cape]
#3082477
10/02/22 01:37 PM
10/02/22 01:37 PM
Cab_Burge
Thanks for the suggestion. I don’t have the motor out yet, in a couple weeks it’ll be out so I’ll so I’ll get a better chance to look at it. Does anybody know if the number 426H-C on the underside of the piston mean anything? I can’t get to the top of the piston until I get the heads off. I'm thinking that 426HC means 426 Hemi Chrysler so they can grab the correct tool (CRS on the proper name of that tool ) to use when they stamp, forge, the aluminum blanks into a piston There are several other brands of race hemi motors like Brad Andersen, Allen Johson performance and as several others I can't think of now, which do not use the same combustion chambers on their race heads hence the need for different piston forging to match the heads The original TRW, Speed Pro factory 10.5 to 1 compression ratio street Hemi pistons had the piston dome height above the deck right at .550, the race pistons with 12.5 to 1 ratio dome height was right at .750, the 13.5 to1 was near .800 with a lot taller and narrower dome
Re: Hemi piston ID
[Re: Cape]
#3082506
10/02/22 03:24 PM
10/02/22 03:24 PM
A727Tflite
Thanks Cab. Combo 69 Dodge Charger 38-3900lbs 478 Hemi 4.28 bore 4.15 stroke G101A 4 speed Advanced clutches twin 8 inch 4.88 gears 10.74@128 @ 3850DA 827hp. Hope the confusion is cleared up. There should be more in it is all I’m saying. I had the heads off a couple years ago to get them CNC but never looked to see if there’s a part number on the dome. I was told they were 12.5:1 but they don’t look that much different then the 9.5:1 mopar ones that came out of it. It started life as a mopar crate 426. The first outing this year the car went 11.37@123 with exhaust. When I went again a couple weeks later I took the exhaust off and did a couple jet changes. That’s where the 10.74@128 came from. Then the yoke split in half. If I could post the pictures of my 9.5:1 pistons and the ones in it now you’d see the difference and if I could post my buddy’s piston which is 13.5:1 you’d really see the difference. His is the exact same combo just the pistons are different. A bit clearer now- the car doesn’t perform to your satisfaction, and the 827 hp came from a dyno test? There could be a million things wrong here - but if it dynoed at 827 I doubt the pistons are your issue. According to the calculators you are off around 5 tenths using that altitude. Going from 11 to 1 to 13 to 1 back in the day was worth about 2 mph and a tenth and a half. May be with climate change it’s more now.
Re: Hemi piston ID
[Re: A727Tflite]
#3082560
10/02/22 08:01 PM
10/02/22 08:01 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
I didn't think CP had shelf hemi pistons either.
No part number on mine
Re: Hemi piston ID
[Re: Cape]
#3082669
10/03/22 10:28 AM
10/03/22 10:28 AM
INTMD8
Lake Villa Il
I checked again and mine do have a job number on the underside. The 426 HC is the forging number. You would have to measure everything of course but you would probably need around 100cc dome for 12.5-1
Re: Hemi piston ID
[Re: Cape]
#3083169
10/04/22 10:04 AM
10/04/22 10:04 AM
INTMD8
Lake Villa Il
Curious if you have the dyno sheet and what rpm were you shifting at?
As Transman alluded to, making 827 at 8000, it should still put down numbers for that power level even if the compression is less than you thought.
Might even need more gear if you're shifting it at 8400 or so
Re: Hemi piston ID
[Re: Cape]
#3083499
10/05/22 09:50 AM
10/05/22 09:50 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
How are you launching it? 60 foot? That cubic inch making that kind of power is gonna have a pretty high torque peak. My 575" hemi makes similar power and needs a 5,000 rpm launch. Yours should be a lot higher.
Re: Hemi piston ID
[Re: Cape]
#3083507
10/05/22 10:12 AM
10/05/22 10:12 AM
INTMD8
Lake Villa Il
Maybe I'm misunderstanding but it peaks at 8000? Would need to do the math on it but you would need to shift it past peak hp so you have max average hp going down the track.
Re: Hemi piston ID
[Re: Cape]
#3083601
10/05/22 04:35 PM
10/05/22 04:35 PM
Cab_Burge
