Re: lifters
[Re: 440Jim]
#3082029
09/30/22 04:09 PM
09/30/22 04:09 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I like those direct lube lifters with the oil hole on the face. Some brands might need different length pushrods, so check it. I used Howards EDM lifters on my current flat tappet cam and no issues. I think they are AMC lifters because they oil through the the pushrods and they are 1/8 taller than my old Comps so yes some brands my be taller. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: lifters
[Re: DusterKid]
#3082062
09/30/22 07:50 PM
09/30/22 07:50 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I use PPP tool steel lifters on my AMC stocker. They have the EDM hole on the face. You almost need a magnifying glass to see it, it’s that small.
1979 AMC Spirit, NHRA Q/SA
Re: lifters
[Re: longram60]
#3082074
09/30/22 08:18 PM
09/30/22 08:18 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I had five years on my EDM lifters from Hughs on a .650 lift cam in my small block. I didn’t mic everything yet but they look good and the car was still running 6.0’s.
Re: lifters
[Re: Cab_Burge]
#3082080
09/30/22 08:39 PM
09/30/22 08:39 PM
Posts: 9,514 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Since the edms are pressurized right on the lobe wouldnt one think its many many times better then splashed oil? Just setting up a cam we see how much oil/lube the lifter wipes off the lobe. Just on setup lashing the valves I see the lobes start to wipe dry so every 2-3 turns I got the oil can out, looks to do the same with cam lube. So why wouldnt pressurized oil from the lifter base to lobe not be very helpful?
STOP POTATO HATE!
