My suggestion get the heck away from the STOCK cam core. If you are using a raised cam block why would you have a stock cam core? I am going to assume that cam was NOT in a raised cam block, as that would make no sense at all.
no, this cam was in my street bracket car. I had someone convince me to get Bullet to make a custom grind cam to match my combination. Sadly I went no faster than the Comp Cam roller I was already using, but we pressed on with that cam, but it broke on the last day of its second season of use. I put the old Comp Cam back in & it's run for 15 years? in total now, & easier on parts.
The block I was looking into raised cams is an Indy Block I bought that I'm considering going 572 with.
