Centrifugal super charge racers, how many on here? #3080863
09/26/22 02:18 PM
09/26/22 02:18 PM
Cab_Burge Offline OP
I'm in the middle of buying the parts needed to build a 551 C.I. BB Mopar wedge motor with a set of B1-MC heads using a Holley Dominator EFI system with a Vortech V30-123A crank driven super charger using E85 fuel.
Any help on this will be greatly appreciated, such as what parts are good and which parts to stay away from.
I'll buy and use either a Jesel paired shaft rocker arm system or a similar set up from T.D. B1-MC heads prep by CFE, Hogan custom made EFI intake with dual injectors per cylinder, Weldon crank driven mechanical fuel pump, dual line external oiling system, maybe dry sump oiling system later luck
Koleno high nickel cast iron block, 4.5 bore x 4.375 stroke Bryant full counter balanced crank, rods and pistons type and brand to be determine in the near future.
All help is appreciated, I liked to get this right the first time help luck
THANKS
Re: Centrifugal super charge racers, how many on here? [Re: Cab_Burge] #3081011
09/26/22 09:30 PM
09/26/22 09:30 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I don't have a race engine, but I do have a 408 based on a 360 with a procharger and electronic fuel injection that I run on pump gas on the street. So the main advice I have is use a set up that will control the ignition timing with a computer, and if possible, knock sensors. My system works great on the street with 6 lbs of boost and 91 octane fuel. By the specs I gave I am not leaning on it at all, it makes around 600HP and gets 20mpg if you drive it at the speed limit. I have messed with a few Holley systems and they like to advance the timing too much sometimes. You always need to use the lap top software to tune so you can adjust the timing maps. If you use the handheld it asks for three points Idle, Cruise, and WOT then draws a curve. Full advance starts at 2,000rpm on the ones I messed with. Mine is a FiTech and it has a separate timing map for boost conditions, I would ask Holley if they offer something similar.
Re: Centrifugal super charge racers, how many on here? [Re: jwb123] #3081263
09/27/22 07:52 PM
09/27/22 07:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I got one
Re: Centrifugal super charge racers, how many on here? [Re: Cab_Burge] #3081279
09/27/22 08:32 PM
09/27/22 08:32 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
I'm running a Procharger on my car. Looks like you have a good foundation but I have mixed feelings on using Hogans for a forced induction set up due to some bad experiences some friends had on a turbo combo. I think N/A carbureted combos are their strength.
Some other general comments: If you haven't bought your ignition system yet just go straight to individual coils and let the dominator control everything. Make sure the rest of the car and driveline from the flywheel back is ready because you'll be making a ton of power. One more thing - anything you buy that you might need support with in the future - like the converter, shocks, EFI, the blower etc. - buy it from someone that has done this before and will provide some service after the sale. Don't get those parts from a Jegs or Summit kind of place or shop by price. Pay a little extra for a part from an experienced seller and you'll buy their wisdom too.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Centrifugal super charge racers, how many on here? [Re: Cab_Burge] #3081667
09/29/22 11:46 AM
09/29/22 11:46 AM
MI
Jeff440sc Offline
Jeff440sc  Offline
MI
Curious why an iron block, do you feel an iron block can withstand the power your combination will make ? The V30 can make 2500hp.
I would think you would want to run an Indy or Keith or another brand aluminum block. I have a mega block with a screw charger and am afraid to turn up the boost because machine shop told me my mega block will break if I turn it up despite having thick cylinders.. they think my mega block is the weak link.
I am using center bob crank to help cap walk and not going past 7000 rpm but would really like to know how they determined the hp rating of a cast iron block like the Koleno or MP wedge mega block.
If it was true it would not make sense to use an iron block if your going to make 2500 hp unless you can get away with it because of a the gradual ramp in power turbos /centrifugal chargers have vs screw charger which is all in at the release of the brake.
Jeff
Re: Centrifugal super charge racers, how many on here? [Re: Jeff440sc] #3081708
09/29/22 02:13 PM
09/29/22 02:13 PM
All the aluminum blocks that I have had friends' race that had both aluminum and aftermarket race cast iron block made more power and went faster and lasted longer on the ring sealing with the iron blocks versus using the aluminum block motor with the same combination of parts shruggy
I really wish that Dart, World or Bill Mitchell would have Mopar wedge and hemi block made out of compact graphite iron blocks made here in the U.S.A. luck Compact Graphite Iron is a lot stronger than regular cast grey iron scope
I've been told that the high nickel iron blocks are stronger than the cast grey iron blocks are, I wish I could buy several more Koleno high nickel race wedge blocks: luck:
Hopefully soon luck
Jeff, I'm hoping to start out with a 2000 HP combination by turning the speed down on the super charger to start with and manage the pressures with the help of two blow off valves set for 30. LBs or less.
I'm new to the racing a supercharge car, let alone on E85.
Vortech says that V30-123A is capable of 2700 to 2800 HP at 45PSI flowing 4000 CFM. When I ask about the C.I. having a effect on the power, they said nothing confused
This whole deal on no prep heads up drag racing is all new to me shock grin
At 77 yrs. old maybe I should take up golfing or some other less strenuous sport on my time and pocketbook whistling
I do have another motor on NOS to start sorting the new car out with before throwing the kitchen sink at it wrench devil
It is a KB aluminum wedge block 572 C.I. 14.5 to 1 compression ratio with a sheet metal tunnel ram intake with two Mark Sullens E85 Domintors with two kits on it, one spray bar kit with jetting for 150 HP and another Induction Solution perimeter plate capable of 500 HP with a controller for both kits. Two plates under both carbs: luck:
Thanks to all of you that have pitch in on this: up:
Re: Centrifugal super charge racers, how many on here? [Re: Jeff440sc] #3081747
09/29/22 05:01 PM
09/29/22 05:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Jeff
I guess we all have opinions. I personally think the mega block would hold a whole lot of power.
2011 Drag Pak Challenger
Re: Centrifugal super charge racers, how many on here? [Re: rickseeman] #3081842
09/29/22 08:46 PM
09/29/22 08:46 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I just put mine back together
Re: Centrifugal super charge racers, how many on here? [Re: FastmOp] #3081861
09/29/22 10:07 PM
09/29/22 10:07 PM
That looks like a Turbo to me, is it?
If so what size and how fast is your car and what fuel and weight is it.?
All help appreciated bow
Re: Centrifugal super charge racers, how many on here? [Re: Cab_Burge] #3082007
09/30/22 01:13 PM
09/30/22 01:13 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
This car is turbo. I have a procharger for a gen 3 hemi in a Road Runner. Motor is in machine shop now.
