Re: Parking brake won't hold, what am I missing?
[Re: CUDASCOTT]
#3081015
09/26/22 10:04 PM
09/26/22 10:04 PM
Posts: 7,354 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Easy fix... these.
If ya cant get your lady to put them in place train one of your doggies.
STOP POTATO HATE!
[Re: cudaman1969]
#3081053
09/27/22 08:01 AM
09/27/22 08:01 AM
Posts: 4,996 nowhere
Sniper
nowhere
he's (maybe she's. or "it's") the same on every forum they post on. my post was to illustrate the fact, for the rest of the people in the thread, the facts on the emergency brake, as posted by an insurance company.
Yes, gloss right over the fact that your insurance company quote, lol, contains a glaring and factually incorrect claim that it reduces engine wear in the very first paragraph. You uncritically accept it because it supports your equally incorrect opinion of how the parking brake system functions. And you obviously have no clue how an emergency system works. You are right, because they do not have one. You ever wonder why the feds mandated a dual circuit hydraulic braking system? Because the parking brake couldn't do the job. Half the hydraulic system still worked better than the parking brake. Ever wonder why the owner's manual tells you to apply the service brakes before setting the parking brake? Because the parking brake cannot fully set the rear brakes all on it's own. Just because you can hammer in a nail with Vice Grips doesn't make it a hammer.
[Re: cudaman1969]
#3081054
09/27/22 08:02 AM
09/27/22 08:02 AM
Sniper
nowhere
“That little hand parking brake was not going to do anything, and I never saw it stop it when I was a kid so I knew not to count on it when I got my Road Runner in 1969.”
Don’t knock it till you’ve tried it. Believe me it works just fine Bet you use compression fittings on brake lines too.
[Re: Sniper]
#3081057
09/27/22 08:25 AM
09/27/22 08:25 AM
Posts: 693 Almost Heaven
Bob Stinson
Almost Heaven
The one thing I remember from High School is a teacher who explained to us that if you ever need to use the parking brake in an emergency to be sure to pull the handle or hold the button in so it doesn't lock. Unless you want to do a bootlegger's turn, then lock 'er up.
69 road runner A12 ex-racer 71 Duster w/ a 400
[Re: stumpy]
#3081122
09/27/22 12:00 PM
09/27/22 12:00 PM
Posts: 12,673 Central Florida
larrymopar360
I'm tired...Very tired.
Central Florida
Right, it's really not a big deal on the name. Brakes changed over the years. I do know from my immature teen years the parking/emergency brake would definitely stop the car by locking the rear wheels  Friends and I would have a little fun when our tires were getting old anyway.
Facts are stubborn things.
[Re: Sniper]
#3081177
09/27/22 03:07 PM
09/27/22 03:07 PM
Posts: 7,079 fredericksburg,va
cudaman1969
fredericksburg,va
Yes, gloss right over the fact that your insurance company quote, lol, contains a glaring and factually incorrect claim that it reduces engine wear in the very first paragraph. You uncritically accept it because it supports your equally incorrect opinion of how the parking brake system functions. And you obviously have no clue how an emergency system works. You are right, because they do not have one. You ever wonder why the feds mandated a dual circuit hydraulic braking system? Because the parking brake couldn't do the job. Half the hydraulic system still worked better than the parking brake. Ever wonder why the owner's manual tells you to apply the service brakes before setting the parking brake? Because the parking brake cannot fully set the rear brakes all on it's own. Just because you can hammer in a nail with Vice Grips doesn't make it a hammer. Like I said you have no clue, I’ve never had a problem locking up the back brakes with an emergency brake and stopping the vehicle, just takes a man to do it, no wimps.
[Re: stumpy]
#3081199
09/27/22 04:45 PM
09/27/22 04:45 PM
Posts: 19,120 in a cattle trailer down by th...
Guitar Jones
Sniper why are you arguing over the name. When brakes were single circuit it was considered an emergency brake. When brakes went to dual circuit it became a parking brake. Single circuit brakes were around for a long time and the emergency brakes saved as lot of people from crashing. And before that it was a parking brake as most cars were stick shift and the early automatics didn't have a park feature, so there is that. People called them emergency brakes, but that was never their intended purpose. Show us in an owners manual or FSM where it is ever called anything other than a parking brake. Hell on our 2019 Ram you can't even apply that parking brake while the truck is in motion.
I raise chickens, so I am literally a chicken tender.
The Scamp is sold, now just two old trucks and one newer one. '92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#3081295
09/27/22 09:13 PM
09/27/22 09:13 PM
Posts: 9,557 Freeport IL USA
poorboy
Freeport IL USA
Funny thing. The laws in IL require a modified or specially built vehicle to have functioning "Emergency brakes." Guess its a good thing that law isn't enforced very much. After that 1st inspection, they forget about it.
I've used the "hand" brake to stop a vehicle, more then once, after the regular brakes have failed. It wasn't fun, or a very fast stop, but it did work. One time was with a modern dual reservoir master cylinder. When a brake line, or brake hose fails, it will still empty the master cylinder with a couple pumps of the pedal. Many of the current plastic brake reservoirs do not have a separation between the two chambers, except possibly a small reserved area that can still empty. .
[Re: cudaman1969]
#3081351
09/28/22 07:34 AM
09/28/22 07:34 AM
Sniper
nowhere
You know you've lost the argument when you have to resort to crap like that for a response.
[Re: Sniper]
#3081395
09/28/22 10:04 AM
09/28/22 10:04 AM
cudaman1969
fredericksburg,va
You know you've lost the argument when you have to resort to crap like that for a response. No I’ve never lost an argument, I go to many sources for the right info first. I’ve asked at least 5 car repair shops (at least 20 or more years in business), everyone said EMERGENCY brake, I grew up in 50s and 60s and worked at the Dodge repair shop it was referred to as an emergency brake and was referred from 1910 to my time as an emergency brake, and don’t give a rats ass about what any ‘book’ called it. It was called ‘parking brake’ for liability issues only. Can you understand why? How do I know this? I Do have some lawyers in the family. Worse than arguing with a women on here sometime, watch CNN much?
[Re: Bob Stinson]
#3081466
09/28/22 02:30 PM
09/28/22 02:30 PM
Posts: 1,416 Phila
PhillyRag
Phila
The one thing I remember from High School is a teacher who explained to us that if you ever need to use the parking brake in an emergency to be sure to pull the handle or hold the button in so it doesn't lock. Unless you want to do a bootlegger's turn, then lock 'er up. So True: 1 hand on wheel, other pulling brake release, left foot pumping emerg pedal. Had to do that few times over the years. It sure beats having to shift into Park.
[Re: cudaman1969]
#3083391
10/04/22 08:25 PM
10/04/22 08:25 PM
Sniper
nowhere
You know you've lost the argument when you have to resort to crap like that for a response. No I’ve never lost an argument, I go to many sources for the right info first. I’ve asked at least 5 car repair shops (at least 20 or more years in business), everyone said EMERGENCY brake, I grew up in 50s and 60s and worked at the Dodge repair shop it was referred to as an emergency brake and was referred from 1910 to my time as an emergency brake, and don’t give a rats ass about what any ‘book’ called it. It was called ‘parking brake’ for liability issues only. Can you understand why? How do I know this? I Do have some lawyers in the family. Worse than arguing with a women on here sometime, watch CNN much? Alzheimer's is a [censored]
