Re: 72 340 engine and 727 trans
[Re: UCUDANT]
#3080190
09/24/22 07:59 AM
09/24/22 07:59 AM
Posts: 152 Ontario Canada
Bennoel 10
Ontario Canada
The adjustment screws aren't at an angle on that carb, it's not a 71 $$ Yes I agree it's not a 71 carb or are any other accessories. It's all date coded 1972 it's just the block that was cast in 1971 and it has a steel forged crank as opposed to the cast crankshaft that came out at some point. It was also removed from a 1972 vehicle.
[Re: Redbird]
#3080446
09/25/22 07:46 AM
09/25/22 07:46 AM
Bennoel 10
Ontario Canada
If the block was cast in 1968 and then finally installed with 1970 #'s on it it is a 1970 motor.
Most everyone wants their items to be 1971 or before.
Blocks were cast and sometimes sat around for a while.
You seem to have a 1972 motor.
I agree that if you could get your 1972 motor to turn over then your chances of selling would be much better. Best of luck. First and foremost I appreciate all input and I agree with your post. Now I listed it as a 1972 340 and 727 with a 1971 casting date which makes me believe that is why it has a steel crankshaft as opposed to the later cast crankshaft. I'm not trying to figure out what I have but what is the going price for a engine/trans that has been together since it was manufactured ??? Thanks again for all opinions.
[Re: Fat_Mike]
#3080638
09/25/22 07:53 PM
09/25/22 07:53 PM
Posts: 348 La Verne, CA
lakerism
La Verne, CA
Marvin's Mystery Oil might break it loose...
[Re: lakerism]
#3080691
09/25/22 10:30 PM
09/25/22 10:30 PM
Posts: 27,024 Shopping @ HoBo Fright
340SIX
Marvin's Miracle Oil might break it loose... John Travolta shot Marvin and he did not even have an opinion. I think Marvel Mystery Oil might work though.
[Re: 340SIX]
#3081051
09/27/22 07:52 AM
09/27/22 07:52 AM
Posts: 3,669 Arlington, Texas
bobby66
Arlington, Texas
Marvin's Miracle Oil might break it loose... John Travolta shot Marvin and he did not even have an opinion. I think Marvel Mystery Oil might work though. My Grandad was a big fan of that stuff.
[Re: bobby66]
#3081063
09/27/22 08:44 AM
09/27/22 08:44 AM
340SIX
Marvin's Miracle Oil might break it loose... John Travolta shot Marvin and he did not even have an opinion. I think Marvel Mystery Oil might work though. My Grandad was a big fan of that stuff. It is good stuff. Will fix a ticking lifter etc. Works,as,air tool lube. Sea foam Works on gas really good too for fuel system clean up. I keep both on the shelf.
[Re: 340SIX]
#3081091
09/27/22 10:24 AM
09/27/22 10:24 AM
Posts: 8,116 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
The original poster wants a value for a 72 340. I'd say that it being stuck makes the estimate more difficult, and it may scare some buyers (why folks suggest you free it up). If it's still standard bore I think that adds value. A body V8 K frames are worth a few bills these days The carb can be worth about $300 as a core to someone seeking that exact #. For reference I paid five or six hundred bucks for the last 340 block I bought 2 years ago (standard bore). A good complete 340 long block with motor mounts, valve covers, early alternator, oil filter adapter, I'd say these days maybe up to $1200-1500
