Page 6 of 15 1 2 4 5 6 7 8 14 15
Re: Slow progress [Re: n20mstr] #3075077
09/07/22 10:20 AM
09/07/22 10:20 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Originally Posted by n20mstr
Originally Posted by racerx
That's a pretty small cell...you tow to the water box and on the return road?
Yes we tow up and back, sometimes drive back. Plus im only racing 1/8 mile
Got cha up nice build.
Re: Slow progress [Re: n20mstr] #3079871
09/23/22 10:00 AM
09/23/22 10:00 AM
On the parachute mount
N
n20mstr Online content OP
n20mstr  Online Content OP
N
Little more progress , dyno and picked up new engine . Sat it in for mock-up
....BAD A$$ STREET CAR.....
Re: Slow progress [Re: n20mstr] #3079932
09/23/22 12:08 PM
09/23/22 12:08 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
right side up
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Slow progress [Re: bigdad] #3080615
09/25/22 07:49 PM
09/25/22 07:49 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Are you going over to Coil near Plug ignition Tony?
Alan Jones
Re: Slow progress [Re: LA360] #3080663
09/25/22 09:50 PM
09/25/22 09:50 PM
N
N
I ran coil on plug even with the carburetor. Yes still going to be COP . I was using a Holley dominator ECU for nitrous control and the ignition. Now it’s 100% EFI
Re: Slow progress [Re: n20mstr] #3081929
09/30/22 10:12 AM
09/30/22 10:12 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Bad mofo!
Re: Slow progress [Re: HardcoreB] #3082051
09/30/22 06:51 PM
09/30/22 06:51 PM
N
N
Originally Posted by HardcoreB
Bad mofo!
Dyno results say …… yes it is up
Can’t wait to see what it makes on the hose primer
Re: Slow progress [Re: n20mstr] #3082140
10/01/22 09:29 AM
10/01/22 09:29 AM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
I'm loving the progress updates. It was already badass before, and is even more badass now!!
Re: Slow progress [Re: Blusmbl] #3082155
10/01/22 10:37 AM
10/01/22 10:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Yes, exactly my thoughts. Tony, can you say what it dyno'd? Or what you think it'll make on spray? If not, I understand.
Re: Slow progress [Re: HardcoreB] #3082175
10/01/22 11:26 AM
10/01/22 11:26 AM
N
N
I have petitioned a weight break for mopar bb in ultra street for a couple years now . I have raced as much as asked to get the weight breaks I asked for . Now , a BB mopar nitrous combination can weigh 50lbs less than a Pontiac , and 300lbs less than a BB Chevy .
Now , that being said , let’s just say the field has been leveled !
The HP is GOOD and it will get 600? Of nitrous added
I will say I was surprised to see the hp keep going up from 7300 to 7800 as most B1 combos seem to stop making HP at 7300
Re: Slow progress [Re: n20mstr] #3082212
10/01/22 12:44 PM
10/01/22 12:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Looking forward to seeing track results. Quality of the build is fantastic.
Doug
Re: Slow progress [Re: n20mstr] #3082218
10/01/22 12:56 PM
10/01/22 12:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW my last three B1 combos have made peak power well past 7300. Mylatest one peaks at 7800...But alot of Mopar guys just dont want to go there IMO
As Always bada$$ car and combo cant wait to see the end result.
Re: Slow progress [Re: Al_Alguire] #3087280
10/18/22 08:46 PM
10/18/22 08:46 PM
N
N
Radiator and water pump mounted
C3758016-2C4B-4D02-BA7E-BA5B47FDD99D.jpeg379F779E-4875-48F2-9223-F57F75E1B609.jpeg7E575729-8AF2-4D24-93B7-AF07600607AC.jpeg
Re: Slow progress [Re: n20mstr] #3102256
12/14/22 01:50 PM
12/14/22 01:50 PM
N
N
I must be good …. Only took two licks of body filler (after epoxy primer )
Re: Slow progress [Re: n20mstr] #3102266
12/14/22 02:02 PM
12/14/22 02:02 PM
N
N
The current version of Ultra Street rules have been released. A BB 588 Mopar can be 2925 with up to a .050 jet in a direct port or 2875 with a plate (unlimited jet) . So its looking pretty good to run a BB Mopar.....IF you dont like money... grin shruggy
Re: Slow progress [Re: n20mstr] #3103836
12/20/22 09:14 AM
12/20/22 09:14 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Mopars to the front! That's interesting considering the NA 10.5 Pontiac gets to be 100 pounds less than a BBMopar. (hopefully that will be adjusted/corrected too) Regardless, I feel what you have lobbied for is fair!
Re: Slow progress [Re: n20mstr] #3103846
12/20/22 09:42 AM
12/20/22 09:42 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Tony, would you post the rules here? I can't access them currently.
Re: Slow progress [Re: HardcoreB] #3103893
12/20/22 12:22 PM
12/20/22 12:22 PM
N
N
https://racertra.com/competition/rules/US.pdf
Re: Slow progress [Re: n20mstr] #3110326
01/09/23 12:52 PM
01/09/23 12:52 PM
N
N
Getting there , the black you see in the rust pits is Por15 . This was original paint on the frame rails , so there were some thin spots that had a little surface rust . Inside the rails look pretty good . This car has been garaged since 1983? So it’s pretty clean …..lol
Re: Slow progress [Re: n20mstr] #3110328
01/09/23 12:57 PM
01/09/23 12:57 PM
N
N
IF you wondering how i get the por15 to stay in only the rust pits.....i paint the area with por15, then come back next day and pass some 180 over it. It comes right off the "clean" metal but stays on the rust spots/pits. It seems to work ok, then i gave it two coats of epoxy primer and two coats of urethane primer.
