Re: Crank endplay?
[Re: rebel]
#3080197
09/24/22 08:37 AM
09/24/22 08:37 AM
Posts: 16,790 Western NC
440Jim
Western NC
The manual I have says the factory spec was 0.002" - 0.007", with 0.010" maximum. My aluminum block has 0.005" with no issues. Good question on yours, but I don't have experience that tight with an aluminum block. But my feeling is you are OK, let's see if anyone posts experience.
1993 Daytona, 1973 Cuda 440, 2009 Challenger 5.7 Hemi, 2015 RAM 1500 5.7 Hemi 8-speed auto, Link to 572 B1 - Part 1
Re: Crank endplay?
[Re: 440Jim]
#3080208
09/24/22 09:14 AM
09/24/22 09:14 AM
Posts: 4,465 On the parachute mount
n20mstr
I have always ran .007 - .0010 . What block is it ? My Indy block the crank was hitting one of the caps and it needed a little touch up on the mill to allow the crank to float as it should . Check all the caps for clearance also
....BAD A$$ STREET CAR.....
Re: Crank endplay?
[Re: rebel]
#3080287
09/24/22 02:17 PM
09/24/22 02:17 PM
Posts: 40,855 Bend,OR USA
Cab_Burge
Re: Crank endplay?
[Re: rebel]
#3080391
09/24/22 10:02 PM
09/24/22 10:02 PM
Cab_Burge
You might want to try adding a little more clearances, .0015 to .0020 on both the front and back sides of the thrust bearing by sanding it on some medium grit sandpaper on a really flat surface, measure carefully while doing that  Drag race motor live a lot longer with looser rotating clearances than they do with them a tiny bit to tight
Re: Crank endplay?
[Re: Cab_Burge]
#3080576
09/25/22 03:53 PM
09/25/22 03:53 PM
Posts: 1,192 New York, USA
Chargerfan68
New York, USA
You might want to try adding a little more clearances, .0015 to .0020 on both the front and back sides of the thrust bearing by sanding it on some medium grit sandpaper on a really flat surface, measure carefully while doing that  Drag race motor live a lot longer with looser rotating clearances than they do with them a tiny bit to tight I agree with Cab…..and if you do this, place the bearings together (same orientation as when installed) when clearancing them on flat surface , to keep them square. As opposed to sanding each half separately.
Re: Crank endplay?
[Re: Chargerfan68]
#3080594
09/25/22 04:55 PM
09/25/22 04:55 PM
Posts: 2,285 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Forgive me if I'm mistaken, but aren't you supposed to take it off the front side? I agree with an alloy block needing another thou or 2 because of the aluminum growth.
2011 Drag Pak Challenger
