BLOWING SMOKE ADDITIVES??? #3080260
09/24/22 12:27 PM
09/24/22 12:27 PM
Amherst
P
plumcrzyTA Offline OP
P
Amherst
I HAVE A 68 BARRACUDA 318 JUST NOTICED IT BLOWWING SMOKE IT DID WHEN I USED TO START BUT NOW IT KEEPS GOING..WANTED TO KNOW IF THERE ARE ANY GOOD ADDITIVES TO HELP WTH THAT????? THX!!!! DAVID
Re: BLOWING SMOKE ADDITIVES??? [Re: plumcrzyTA] #3080265
09/24/22 01:10 PM
09/24/22 01:10 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
WHAT?!?! WHAT?!?!
times for valve seals, is my guess. or you have a leak on the intake gasket. OKAY?!?!?! additives to stop this? panic
Re: BLOWING SMOKE ADDITIVES??? [Re: Golden-Arm] #3080300
09/24/22 04:32 PM
09/24/22 04:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You just waste money trying to stop smoke with magic additives. down
Re: BLOWING SMOKE ADDITIVES??? [Re: stumpy] #3080377
09/24/22 09:42 PM
09/24/22 09:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
lot's of snake oil out there. Any oil thickener will help as will heavier weight oil. but it's a band aid and likely time for a rebuild. You wanted that crate motor anyway right ?
Re: BLOWING SMOKE ADDITIVES??? [Re: TJP] #3080378
09/24/22 09:44 PM
09/24/22 09:44 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
A good old school re ring, seals and bearing job is still dirt cheap and would outlast most of us here.
STOP POTATO HATE!
Re: BLOWING SMOKE ADDITIVES??? [Re: plumcrzyTA] #3080382
09/24/22 09:57 PM
09/24/22 09:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
And here I thought it was for doing this with a car, dumb me wink blush grin
Re: BLOWING SMOKE ADDITIVES??? [Re: A12] #3080453
09/25/22 09:33 AM
09/25/22 09:33 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Might do some testing to see what is causing the smoke rather than put in additives.
Re: BLOWING SMOKE ADDITIVES??? [Re: plumcrzyTA] #3080551
09/25/22 03:24 PM
09/25/22 03:24 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
There is no additive that will stop a worn engine from smoking. You have to decide if it's time to tear it down and fix it or put up with the smoke.
Re: BLOWING SMOKE ADDITIVES??? [Re: elmor353] #3080559
09/25/22 03:37 PM
09/25/22 03:37 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've heard the old-timers say Bon-Ami would seal up the rings. Haven't heard it since the 70's though. work
Re: BLOWING SMOKE ADDITIVES??? [Re: bobby66] #3080562
09/25/22 03:49 PM
09/25/22 03:49 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Kind of sometimes works if the piston rings are not worn out.
If you have stuck rings pouring a few ounces of a mixture of diesel/kerosene and Techron in through the spark plug holes and letting it sit in the cylinders for a few days might work with freeing up any sticky piston rings. DAMHIK wink
Re: BLOWING SMOKE ADDITIVES??? [Re: bobby66] #3080653
09/25/22 09:32 PM
09/25/22 09:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I did watch a guy do it with a 305 Honda back in the late 70's. But, it had new rings that didn't appear to be seating. it did stop the smoking but I'm not sure for how long .
Another thing to keep in mind is there are compression and oil control rings. I'm going to guess both are sticking or are stuck. Repeatedly soaking the c-ap out of the cylinders with Berryman's B12, Marvel mystery oil or other solvents may help or make it worse. twocents
Re: BLOWING SMOKE ADDITIVES??? [Re: plumcrzyTA] #3080808
09/26/22 12:09 PM
09/26/22 12:09 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Any one that says you can fix this with any brand of "mechanic in a can" is also Blowing Smoke. Sorry couldn't help it.
Re: BLOWING SMOKE ADDITIVES??? [Re: plumcrzyTA] #3080819
09/26/22 12:47 PM
09/26/22 12:47 PM
IMGTX Offline
IMGTX  Offline
Start by verifying where the smoke is coming from.
Are you using/loosing antifreeze? If so it could be a head gasket.
Run a compression check and look for a low cylinder. Squirt a little oil in that cylinder and see if it noticeably increases. If it does, it's your rings. Time to rebuild.
Sometimes a very low compression is a hole in the piston and oil in the cylinder won't help but a small camera in the cylinder will let you see. They are cheap on Ebag
You can also run a leakdown test to test the rings. The tool is pretty cheap too.
If you are not loosing antifreeze and the compression is good then it very well could be bad valve seals. You can replace them in the car but usually a valve job is the best method.
But to answer the original question... No chemical really fixes worn or broken parts so nothing you can really do but repair the engine or rebuild it.
Re: BLOWING SMOKE ADDITIVES??? [Re: plumcrzyTA] #3080995
09/26/22 09:39 PM
09/26/22 09:39 PM
Indianapolis
Geeorge Offline
Geeorge  Offline
Indianapolis
I would check out and clean the pcv valve and hose first
Re: BLOWING SMOKE ADDITIVES??? [Re: Geeorge] #3081477
09/28/22 03:51 PM
09/28/22 03:51 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Mechanics in a can..lol
an additive has no eyes or a GPS to zone in on what is causing your smoke, it just goes around the oiling system and tries to seal and clog up anything..or swell up rubber seals like in those stop leak crap...
