Re: Solid lifters??
[Re: HotRodDave]
#3061379
07/21/22 02:46 PM
07/21/22 02:46 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Why would it not be possible to run solid lifters and adjust them the way it is done on [censored] cars except different length pushrods instead of different lash cap bucket thingies? It may get expensive to order a bunch of very slightly different length pushrods but it would allow to the lightest possible rocker with no adjuster and a very light lifter... has anyone done anything like this?
My thought would be to order one set how you normally would then measure clearance and order 16 very slightly different ones to fit each individual cylinder. Even ordering 3 or 4 sets like this and playing around with them would be much cheaper than one set of adjustable rockers...
As far as solid lifter are concerned is there any drop in ones available? If not can you just pull the guts out of a stock one and put the cup into the bottom of it somehow? They make adjustable push rods
Re: Solid lifters??
[Re: CSK]
#3061658
07/22/22 03:35 PM
07/22/22 03:35 PM
Dyno1
I looked for a solid drop in style lifter and could not find one. I walked the PRI show and asked all the manufacturers. Jesel does make something but is big $$$. Comp does make a tie bar short travel lifter I installed in my new stocker engine, but I have not dynoed it yet. I do have the new T&D roller rockers and Smith Brothers push rods. I need something that can run to 8000 rpm.
Re: Solid lifters??
[Re: Cab_Burge]
#3073501
09/02/22 08:55 AM
09/02/22 08:55 AM
Posts: 1,117 Loudoun County, VA
Brad_Haak
Loudoun County, VA
The spec sheets for the latest 426 and 5.7 SC Drag Paks say they use solid lifters, but they don't specify from what manufacturer.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Solid lifters??
[Re: Brad_Haak]
#3080268
09/24/22 01:19 PM
09/24/22 01:19 PM
Dyno1
The spec sheets for the latest 426 and 5.7 SC Drag Paks say they use solid lifters, but they don't specify from what manufacturer. I have been searching for a solid lifter for the Gen 3 hemi. I have been told that Jesel does make one, but are in the $3500.00 range. I know quality cost $$$, but that is out of my budget. The only option I see is to buy a new set of lifters from Dodge and remove the guts and shim them up. I did buy the rocker setup from T&D, which is very nice, so I can adjust the lash. Years ago I used the Smith Brothers adjustable pushrods on a LS1 engine. On stock valve spring engines, they may be OK, but on a performance engine with high spring pressures, they flexed to much. .
Re: Solid lifters??
[Re: HotRodDave]
#3080280
09/24/22 02:36 PM
09/24/22 02:36 PM
CSK
Pattison Texas
I would call Johnson Lifters & talk to them ,they make a short travel hydro, NOT Johnson hylift
