Re: Crank endplay?
[Re: 440Jim]
#3080208
09/24/22 10:14 AM
09/24/22 10:14 AM
Posts: 4,670 On the parachute mount
n20mstr
I have always ran .007 - .0010 . What block is it ? My Indy block the crank was hitting one of the caps and it needed a little touch up on the mill to allow the crank to float as it should . Check all the caps for clearance also
....BAD A$$ STREET CAR.....
Re: Crank endplay?
[Re: rebel]
#3080287
09/24/22 03:17 PM
09/24/22 03:17 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Re: Crank endplay?
[Re: rebel]
#3080391
09/24/22 11:02 PM
09/24/22 11:02 PM
Cab_Burge
You might want to try adding a little more clearances, .0015 to .0020 on both the front and back sides of the thrust bearing by sanding it on some medium grit sandpaper on a really flat surface, measure carefully while doing that Drag race motor live a lot longer with looser rotating clearances than they do with them a tiny bit to tight
Re: Crank endplay?
[Re: Cab_Burge]
#3080576
09/25/22 04:53 PM
09/25/22 04:53 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
You might want to try adding a little more clearances, .0015 to .0020 on both the front and back sides of the thrust bearing by sanding it on some medium grit sandpaper on a really flat surface, measure carefully while doing that Drag race motor live a lot longer with looser rotating clearances than they do with them a tiny bit to tight I agree with Cab…..and if you do this, place the bearings together (same orientation as when installed) when clearancing them on flat surface , to keep them square. As opposed to sanding each half separately.
Re: Crank endplay?
[Re: Chargerfan68]
#3080594
09/25/22 05:55 PM
09/25/22 05:55 PM
Posts: 2,629 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Forgive me if I'm mistaken, but aren't you supposed to take it off the front side? I agree with an alloy block needing another thou or 2 because of the aluminum growth.
2011 Drag Pak Challenger
