Fender Scoop Broken Stud Extraction help
#3079863
09/23/22 09:32 AM
09/23/22 09:32 AM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
So I finally bought my first Daytona after many years of looking and started to take care of a few housekeeping things. While driving, I noticed light coming from the front edge of the scoop thinking the front mounting stud needed tightening. I wish that were the case. I pulled the scoop and found that the front stud is broken. I was able to grab the stud "stub" with vise grips but the stud just spins and doesn't unscrew out like I was hoping. Does the stud have some kind of head or bolt cap that prevents it from unscrewing out? Any recommendations what to do next? Thanks.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Fender Scoop Broken Stud Extraction help
[Re: RSI700VIPER]
#3079910
09/23/22 11:24 AM
09/23/22 11:24 AM
Posts: 10,698 North Dakota
6PakBee
North Dakota
I'm no Daytona expert but I am building a clone. The fender scoops I got from Janak are set up for studs that screw into the scoops. I would guess that if you put a little pull on the stud while you are turning it'll come right out.
[Re: A12]
#3080402
09/24/22 11:36 PM
09/24/22 11:36 PM
Posts: 1,750 Phila
PhillyRag
Phila
Mapp/propane torch and heat the post (not the stud) cherry red then grab the stud with the vise grips. You're painting it right? Cherry red as first try would be excessive. Just heat somewhat, twist & pull. The internal threads are probably shot, Stud threads are probably corroded also. Keep the boss intact as much as possible. Easier to fix the threads, or maybe go oversize,
[Re: PhillyRag]
#3080411
09/25/22 12:04 AM
09/25/22 12:04 AM
RSI700VIPER
NW New Jersey
Lots of good tips here. I thought of drilling small pilot holes around the stud then wiggling the darn thing out. Then epoxy glue in a new stud. But the won't work if there is an embedded head.
[Re: RJS]
#3080619
09/25/22 08:09 PM
09/25/22 08:09 PM
6PakBee
North Dakota
Again, I'm no Daytona expert but I thought the scoops were plastic on the original street version. If so, I'm not so sure heat is a good thing.
[Re: 6PakBee]
#3080645
09/25/22 09:14 PM
09/25/22 09:14 PM
RSI700VIPER
NW New Jersey
I just learned on another forum that the stud is more like an upside down hex screw with the head cast into the post. Crap, not good. Might have to cut the whole post off to get it out.
[Re: RJS]
#3080646
09/25/22 09:16 PM
09/25/22 09:16 PM
RSI700VIPER
NW New Jersey
Who cares about all this fixing crap, let's see the car!!!!!!!!!
Ron Here ya go Ron. Pics are when I picked it up in Hughesville PA.
[Re: RSI700VIPER]
#3082245
10/01/22 02:28 PM
10/01/22 02:28 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Up I just learned on another forum that the stud is more like an upside down hex screw with the head cast into the post. Crap, not good. Might have to cut the whole post off to get it out. I am not sure about Daytona scoops but the superbird scoop studs are just plain unplated studs, at least mine was. I just drilled them with progressively larger bits and the heat got most them loose with a final reverse drill bit. A few I used a large soldering iron to get an 1/8" bit real hot to get them out, you will feel the plastic soften a little, then they came right out. My scoops are abs plastic so I bought some abs rod on ebay to replace one broken post and plastic welded that on and threaded it. You wouldn't think plastic would rust that tight to steel but it sure does with the plain studs they used. If you ever mess with rear wing studs make sure you know what you are doing, 2 on each side have a taper pin in them sideways drilled thru the stud before it is cast, those need the wing jigged up in a Bridgeport to drill out a broken one, one of the so called best body shop heros in my state fkd mine up, after I told him to leave them alone. So arrogant he was.
[Re: floyd]
#3082273
10/01/22 03:22 PM
10/01/22 03:22 PM
Posts: 19,310 north of coder
moparx
I have no specific info on Daytonas but would imagine that stud is similar to those used in air grabbers, a-body hood scoops, 71 Challenger R/T 1/4 scoops. Search for “air grabber stud replacement “ and you’ll find some info. I believe they look like this:
Floyd, i think the stud you show is what is used. the "washer head" between the course thread that goes into the stud and the fine thread that is used to retain the scoop[s] is just slightly molded into the scoop stud a tiny bit below the plastic surface, or is slightly exposed, having a few slivers of the plastic stud on the mounting side. this is how i remember the originals being, when i owned my junkyard from 1972-1984/5. not daytona or super bird scoops, [we never had any of those, or hemi cars] but super bee scoops, a-body scoops, etc. [there were several in the yard during this time] i would imagine all scoops had the mounting studs this way.
[Re: moparx]
#3082653
10/03/22 09:25 AM
10/03/22 09:25 AM
Posts: 9,096 Rogue River, OR
Jeremiah
Rogue River, OR
Several years ago I made the mistake of replacing the back light (rear window) in my 66 Coronet. Si,ilar to the OP's saga the original glass was concave and followed the body lines. The new glas was convex and gave the rear winow a bubble top kind of look which made the car look goofy to me. I sold it and found a 4 speed car to build. I'd rather have an original OE beater than an aftermarket laden show poodle for this reason. The cars built off of the reproduxtion parts is a representation of the original. If used as intended most of that stuff will fail.
I
[Re: RSI700VIPER]
#3083148
10/04/22 09:08 AM
10/04/22 09:08 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
If you can find someone with an induction heat tool, that may work. I would cut a slot in the broken part, heat with the tool and stop before the surrounding material became too soft, just enough to break free and back out with screwdriver. I bought one off Amazon last year and have used it countless time when usually all hope was lost in getting a bolt out in a tight spot. Just used on someone's license plate screws that were seized (machine screws in a captive nut on the hatch). I have a knock off amazon one, was cheaper when I bought it. Amazon Inductor Tool
[Re: njmopar]
#3083337
10/04/22 06:36 PM
10/04/22 06:36 PM
Posts: 6,583 SE Pa.
LimeliteAero
SE Pa.
I understand I'm late to the thread but here's what the original superbird scoop hardware looks like. I would say theres nothing really there keeping it in place other than stripped out plastic.
[Re: LimeliteAero]
#3083489
10/05/22 09:19 AM
10/05/22 09:19 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I understand I'm late to the thread but here's what the original superbird scoop hardware looks like. I would say theres nothing really there keeping it in place other than stripped out plastic. Agreed, just years of rust and embedded old Cosmoplast/FRP (fiberglass re-enforced plastic) stuck in the rusted stud threads, if the OP said he could get a set of vise grips on the stud, then there might be enough stud exposed to use a drill, tighten the chuck on the stud, go in reverse and spin/pull at the same time gently/slowly as to not smoke the FRP/plastic, you'll blow the hole out getting the stud out, clean up the hole with a small dremel using a burr to get to some rustfree/clean FRP, then use a bolt 1/4-20 thread, wrap the threads lightly with one wrap of thin white teflon tape, you could use an epoxy/JB Weld/etc, I like to use polyester resin, fill the hole, push in the teflon wrapped bolt, wipe away the excess resin/epoxy/etc, let dry fully, unscrew the bolt, you'll have fresh threads, I always replace/use Stainless 1/4-20 set screws studs and stainless K lock nuts....
