Parking brake won't hold, what am I missing? *UPDATE*
#3079820
09/23/22 03:21 AM
09/23/22 03:21 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Long story short, the parking brake didn't work when I got my '74 crew. Now in FL it wasn't a big deal, but I replaced the front cable, shoes and cylinders, I did not replace the drums, still didn't hold the truck. Everything works as it should and moves freely. So now I'm in the mountains and a parking brake is sorely needed as there isn't a level piece of ground to be found and some spots are pretty steep. So I replaced the drums, still won't hold the truck. Figured the shoes were cheap crap so I replaced them with Napa premium shoes, $80 worth. Now it is only slightly better if I really push the pedal through the firewall. Are the linings really that crappy any more? I haven't done much with drum brakes in the last decade or two. Do the shoes need to seated like some disc pads do? I thought about converting to rear discs like I did my '92 but didn't want to spend that money on it right now. I might put a 1/4 turn ball valve in the front brake line like I did to the rears of the '92. That works well on that truck. Forgot, it's a full floating Dana 60 axle with 12 x 2-1/2 brakes.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Parking brake won't hold, what am I missing?
[Re: Guitar Jones]
#3079825
09/23/22 06:16 AM
09/23/22 06:16 AM
Posts: 10,124 A Red State
SNK-EYZ
A Red State
It might sound like a silly question, but have you adjusted the parking brake cable adjuster????
[Re: SNK-EYZ]
#3079851
09/23/22 08:38 AM
09/23/22 08:38 AM
Guitar Jones
Yes. The shoes expand against the drum and the pedal gets hard before the end of it's travel. It just doesn't stop the truck from rolling. Before replacing the shoes there was very little resistance, now it drags, but very slightly. Not enough to hold the truck.
[Re: topside]
#3079856
09/23/22 09:05 AM
09/23/22 09:05 AM
Guitar Jones
Back in the day, we used to "arc" the shoes so they made full contact with the drums. New shoes mostly just made contact at their leading & trailing edges unless that was done. That said, you'd probably notice poor braking performance in general without full contact. Other than that, the parking brake is pretty much just cable & hardware. Yeah, but that was usually done after turning the drum. I thought of that, but with new shoes and new drums they should match, it looked ok when I set the shoes in the drum. Honestly the brakes aren't all that and a bag of chips anyway, but they are not horrible. I may drive it awhile then get the rear wheels off the ground and see how well the service brakes hold it.
[Re: mopars4ever]
#3079895
09/23/22 10:45 AM
09/23/22 10:45 AM
Guitar Jones
I wounder if the cable is possibly stretching? I doubt that, Like I said the pedal gets really hard, you can't possibly get another click on it. The shoes are pressed as hard on the drum as it can be.
[Re: Guitar Jones]
#3079955
09/23/22 01:17 PM
09/23/22 01:17 PM
Posts: 15,268 Omaha Ne
TJP
Omaha Ne
Back in the day, we used to "arc" the shoes so they made full contact with the drums. New shoes mostly just made contact at their leading & trailing edges unless that was done. That said, you'd probably notice poor braking performance in general without full contact. Other than that, the parking brake is pretty much just cable & hardware. Yeah, but that was usually done after turning the drum. I thought of that, but with new shoes and new drums they should match, it looked ok when I set the shoes in the drum. Honestly the brakes aren't all that and a bag of chips anyway, but they are not horrible. I may drive it awhile then get the rear wheels off the ground and see how well the service brakes hold it. the bolded part of your statement may be worth considering. Also if you have rear contact issues it is unlikely you would notice it as most of the braking is down by the fronts. Most 'parking brakes hold better going forward than back. Another thing I have found is that applying the brakes hard before setting the park brake will better align the shoes resulting in more holding/contact one could aso inspect the shoes to verify the lining contact area
[Re: TJP]
#3079961
09/23/22 01:24 PM
09/23/22 01:24 PM
Guitar Jones
You do realize what a PITA it is to pull the drums off this don't you?
[Re: Guitar Jones]
#3079979
09/23/22 01:55 PM
09/23/22 01:55 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
I've got the same problem with a Duster. Pull that handle as hard as you can and it still won't hold the car on an incline. The car stops fine other than that. New cables, new brakes including new drums that came on a rear end I had built for it. It didn't have the e-brake arm on the shoes at first but I found a couple and installed them. I dunno.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: stumpy]
#3080006
09/23/22 03:12 PM
09/23/22 03:12 PM
Guitar Jones
Dumb question but did you install the short shoes to the front of the backing plate and long to the rear? Primary shoes on the front, secondary shoes on the rear, so yes.
[Re: Sniper]
#3080008
09/23/22 03:18 PM
09/23/22 03:18 PM
Guitar Jones
Even dumber question, do you fully apply the service brake before trying to engage the parking brake lever?
Did you adjust the shoes? Yes the brakes are properly adjusted. I replaced the self adjusters with the drums as some teeth were missing on one of the star wheels, they were probably original to the truck as I believe the drums may have been also. I have not applied the service brake while setting the parking brake, I am going to try that though.
[Re: Bob Stinson]
#3080010
09/23/22 03:22 PM
09/23/22 03:22 PM
Guitar Jones
I've got the same problem with a Duster. Pull that handle as hard as you can and it still won't hold the car on an incline. The car stops fine other than that. New cables, new brakes including new drums that came on a rear end I had built for it. It didn't have the e-brake arm on the shoes at first but I found a couple and installed them. I dunno. I guess I'm not the only one then. I'm going to try a few things, maybe tomorrow if I drive it, and it warms up a little.
[Re: GarageDodge]
#3080100
09/23/22 07:35 PM
09/23/22 07:35 PM
Posts: 6,217 nowhere
Sniper
nowhere
the old parking brakes never worked very good,even when the vehicle was brand new.they always worker better in reverse,but not very good. They are parking brakes, designed to hold the vehicle, not emergency brakes designed to be used when the vehicle is in motion.
[Re: ro23_j]
#3080111
09/23/22 08:06 PM
09/23/22 08:06 PM
Guitar Jones
If the drums were out of round you would have felt that in the parking brake pedal during your test.
[Re: Guitar Jones]
#3080128
09/23/22 09:06 PM
09/23/22 09:06 PM
TJP
Omaha Ne
Find a nice steep hill. Aplly the park brake going forward: establish effectiveness of the PB by itself. Then, release the PB, apply the brakes hard before setting the park brake. Repeat test. relese the PB again. then Apply the parking brake and then hit the pedal hard repeat test. Either should result in better contact but one may work better than the other. Testing on the same hill will identify if either method improves the effectiveness might also try applying the parking brake for short periods while moving to help arc them to the drum. Do allow adequate cool down periods and obviously don't overheat them.
