Heading to NMCA finals at Indy #3079370
09/21/22 05:44 PM
09/21/22 05:44 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
After breaking the motor last year my season has been less than stellar. Minor parts breakage and poor lights have plagued me. Ran GLSSA and the nostalgia event at Milan the past weekend. The back up converter seems much better. Made 21 passes. Friday night made seven 8.99-9.00 passes. Went to final 6 Saturday and last 8 Sunday. my lights came back. Driving the stripe came back. We’ll see what happens. Going to run 9.00 AA/FX index.
Doug
Re: Heading to NMCA finals at Indy [Re: dvw] #3079377
09/21/22 06:01 PM
09/21/22 06:01 PM
tboomer Online work
tboomer  Online Work
Good luck Doug! up
Re: Heading to NMCA finals at Indy [Re: tboomer] #3079384
09/21/22 06:24 PM
09/21/22 06:24 PM
Chesterfield Twp. Mi.
John Burdine Offline
Good luck!
Re: Heading to NMCA finals at Indy [Re: John Burdine] #3079446
09/21/22 10:04 PM
09/21/22 10:04 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
All the Best !
Re: Heading to NMCA finals at Indy [Re: Red440] #3079488
09/22/22 02:08 AM
09/22/22 02:08 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Good luck man!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Heading to NMCA finals at Indy [Re: EvilB1Dart] #3079489
09/22/22 02:16 AM
09/22/22 02:16 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Good luck! boogie
Re: Heading to NMCA finals at Indy [Re: slantzilla] #3079494
09/22/22 05:22 AM
09/22/22 05:22 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Good luck Doug . Have at it .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Heading to NMCA finals at Indy [Re: tex013] #3079501
09/22/22 06:56 AM
09/22/22 06:56 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Good Luck Doug!
69 GTX 68 Road Runner
Re: Heading to NMCA finals at Indy [Re: dvw] #3079515
09/22/22 08:16 AM
09/22/22 08:16 AM
an8sec70cuda Offline
Awesome, good luck!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Heading to NMCA finals at Indy [Re: an8sec70cuda] #3079529
09/22/22 08:57 AM
09/22/22 08:57 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Good luck!!!
Re: Heading to NMCA finals at Indy [Re: dvw] #3079534
09/22/22 09:10 AM
09/22/22 09:10 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Good luck Doug!
Re: Heading to NMCA finals at Indy [Re: dvw] #3079572
09/22/22 10:50 AM
09/22/22 10:50 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
You got this! 9.0 index too
Re: Heading to NMCA finals at Indy [Re: dvw] #3079578
09/22/22 11:00 AM
09/22/22 11:00 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Keep it rolling Doug . We were going to go watch this weekend . Gary
Re: Heading to NMCA finals at Indy [Re: Gabby63] #3079599
09/22/22 11:41 AM
09/22/22 11:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Wish we were there with you..For those that have seen the SM rod failure maybe this will look familiar and why we wont be there. BTW this rod had 6 pulls on the dyno and two passes on it from new.....Pin is still free on piston and rings still rotate..
Re: Heading to NMCA finals at Indy [Re: Al_Alguire] #3079623
09/22/22 01:01 PM
09/22/22 01:01 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Uhhh... ouch eek
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Heading to NMCA finals at Indy [Re: Brad_Haak] #3079647
09/22/22 02:15 PM
09/22/22 02:15 PM
PA
O
Ody1003 Offline
Ody1003  Offline
O
PA
Al, may I ask, Whos' rod, whos' piston..
Re: Heading to NMCA finals at Indy [Re: Ody1003] #3079674
09/22/22 03:40 PM
09/22/22 03:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Piston is CP, they are also new with the dyno passes and two runs. Rod will remain unnamed now as we are having the others xrayed and examined to determine what happened. New rods are on order from Carillo right now and they are rushing them but wont make this weekend. Already got new pins and more new pistons.
Re: Heading to NMCA finals at Indy [Re: dvw] #3079684
09/22/22 04:16 PM
09/22/22 04:16 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Go get 'em Doug. Looks like it might be humid.
'71 Duster
'17 Ram 1500
Re: Heading to NMCA finals at Indy [Re: RMCHRGR] #3079769
09/22/22 09:11 PM
09/22/22 09:11 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Weather is tough. D/A is the best I've run in,around 2000ft. 7-15 mph headwind. 60 ft is dead slow .05-.07 off from last weekend. Ran 9.11, 9.10. We are first out tommorow morning at 8:30am. D/A estimate is -200ft. Still with a 5mph headwind. However the wind switches to tailwind around noon. We have to declare index with-in 30 minutes of 1st qualifier. 9.00 or 9.25? All depends if 60ft is any good. At least the lights were decent .021R, .001 L. It will be a challenge.
Doug
Re: Heading to NMCA finals at Indy [Re: Al_Alguire] #3079786
09/22/22 10:13 PM
09/22/22 10:13 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I ran aluminum rods for years, hundreds of runs and no issues. Then a new set with 50 or so runs and mine looked like yours. That done me in steel rods only, and I really did not notice any performance difference by switching.
