Re: Heading to NMCA finals at Indy
[Re: slantzilla]
#3079494
09/22/22 05:22 AM
09/22/22 05:22 AM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Good luck Doug . Have at it .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dvw]
#3079515
09/22/22 08:16 AM
09/22/22 08:16 AM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
[Re: Al_Alguire]
#3079623
09/22/22 01:01 PM
09/22/22 01:01 PM
Posts: 1,072 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Uhhh... ouch
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Ody1003]
#3079674
09/22/22 03:40 PM
09/22/22 03:40 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Piston is CP, they are also new with the dyno passes and two runs. Rod will remain unnamed now as we are having the others xrayed and examined to determine what happened. New rods are on order from Carillo right now and they are rushing them but wont make this weekend. Already got new pins and more new pistons.
[Re: dvw]
#3079684
09/22/22 04:16 PM
09/22/22 04:16 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Go get 'em Doug. Looks like it might be humid.
'71 Duster '17 Ram 1500
