Wilson Manifolds. Tempting but...
#3078930
09/20/22 01:22 AM
09/20/22 01:22 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I got a call back from Wilson Manifolds.
I had sent my old fabricobbled tunnel rammy efi intake thing to them for professional amusement. Their final determination says it is the wrong piece for my mild 541. They suggested a Performer RPM converted to EFI and one of their 4bbl style throttle bodies.
The quote for parts and labor plus port matching to the template I sent is $2500.
The quote for parts and labor plus a full port job on the manifold is $3600.
Seeing that this 541 is a relatively low power and low rpm piece built for cruising it's hard to justify the extra $1100 for what little gain I'd see. Yes, it's a big inch motor but I doubt it'll top 550 hp with the new intake. Looking at the info I have, the extra work would likely bring 12-15 more hp over the port match.
Am I wrong? Would you drop the extra coin on it?
I'm thinking that if it's not doing what I want I could always send it back for more work.
Initial dyno test attached, valve float and all.
Re: Wilson Manifolds. Tempting but...
[Re: feets]
#3078959
09/20/22 08:19 AM
09/20/22 08:19 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
No. Wilson's prices are outrageous.
[Re: Dragula]
#3078961
09/20/22 08:24 AM
09/20/22 08:24 AM
feets
Senior Management
Senior Management
Irving, TX
One thing I like about going to a 4bbl style throttle body is the ease of installation. I spent quite a bit of time fussing with the kick down linkage with my old intake. Air cleaner installation is also much easier and I don't have to worry about the intake tube interference with the engine accessories such as AC.
[Re: feets]
#3079011
09/20/22 12:11 PM
09/20/22 12:11 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If it was me making that decision I would be choosing between
option A. purchasing the manifold and throttle body and matching it myself
option B. paying them to do a full port job.
Just paying them to do a port match I can easily do myself seems silly.
On the other hand if I really was the one building this engine for myself I would pick a good single plane and 4bbl throttle body, may give up a few LBS TQ very low but they have the best look and a few more HP up top won't hurt, not like you can really use 650+ TQ that is gonna be brutal on U-joints, tires, trans, rear end... hope you got a dana 60 at least. You plan to drive this thing a lot correct?
[Re: feets]
#3079015
09/20/22 12:17 PM
09/20/22 12:17 PM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
What is the expected improvement in performance for $2500 and $3600, respectively?
I'm probably the last person who should comment about somebody dropping a lot of coin for minimal improvement in performance... but I don't see the ROI here at either price point.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: CKessel]
#3079053
09/20/22 02:01 PM
09/20/22 02:01 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
Anything I've ran on the dyno with an elbow vs 4 barrel TB or turning the air a sharp 90 on a 4 barrel throttle body kills power. (Just look at manifold negative pressure as rpm increases)
Not sure what the inside of your custom intake looks like. Wouldn't have any idea of what the power difference could be considering the lack of valve control on the initial test.
May have missed it buy why not just use the Edelbrock 7144 for similar layout?
[Re: an8sec70cuda]
#3079064
09/20/22 02:29 PM
09/20/22 02:29 PM
Posts: 397 NH, USA
toddinNH
Egghead
Egghead
NH, USA
No. Wilson's prices are outrageous. x1000
[Re: dizuster]
#3079068
09/20/22 02:37 PM
09/20/22 02:37 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Maybe I’m reading it wrong, but the 2500 plan includes the rpm manifold, the 4bbl throttle body, and the necessary parts and labor for the fuel rail conversion, and a port match.
How much would that stuff cost if you bought the parts and had the manifold mods done “locally”?
Of course, the cheapest option is to just put the current intake back on.
The bottom of the powerband was fine with it on the motor, and I have to believe there would be “some” improvement in power up top with the new valve springs.
[Re: fast68plymouth]
#3079198
09/21/22 12:43 AM
09/21/22 12:43 AM
feets
Senior Management
Senior Management
Irving, TX
The $2500 includes $395 for the intake, $905 for the low height throttle body with idle air control, intake air temperature sensor, and idle air control. They're modifying the intake for port injection, and building fuel rails. The port match added $400 and they already have my port template. That means the labor for efi conversion with fuel rails is $700.
They think the runners on the current intake are too long, ports are too small, injectors protrude too deeply into the runners, and the plenum is not properly shaped.
[Re: Cab_Burge]
#3079231
09/21/22 08:32 AM
09/21/22 08:32 AM
feets
Senior Management
Senior Management
Irving, TX
I called Wilson and had a good conversation with them on the phone. They were willing to spend a little time doing that without cutting me off. After that, I sent them my manifold to look into modifications. The evaluation of my piece is what lead to the new intake being built.
Wilson products have a good reputation and the people struck me as open, honest, and friendly. That means as much to me as the product they sell. They invested in me so I invested in them.
There are others out there that could do similar work on a similar product. In this case the people earned my business.
