For Sale - Mopar Full Size - Parts - 3rd Quarter #3055020
07/01/22 08:54 PM
07/01/22 08:54 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
3G Hemi bell crank [Re: moparts] #3055601
07/03/22 05:55 PM
07/03/22 05:55 PM
BDW Online content
BDW  Online Content
Mopar 53032456AE Bell Crank, this is the part needed to convert manual gas pedal to drive by wire and maintain kick down functionality needed for the 904/727/518 transmissions behind a 3G Hemi.
Fully tested and functional, includes the wiring harness, $125 includes shipping to US
Also have just the sensors for $100, if you don't need the housing.
Here’s a link on how to set-up:
https://www.youtube.com/watch?v=5H6Jt6G5DcA&t=197s&ab_channel=DIYHEMI
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: moparts] #3056314
07/05/22 02:39 PM
07/05/22 02:39 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
All NOS Switches:
#2809013 67+Newer Washer Pump, Correct $350,
#2947219 Cigarette Lighter Socket Assembly Complete w/Lighter $100,
#3488804 71-9 Turn Signal Switch w/o Cornering Lights $165,
#3488805 71-9 Turn Signal Switch $185,
#2926117 69+Newer 4-Gang Power Window Switch $395,
#2926118 Single Power Window Switches $135ea,
#2583910 + #2864258 66-8 Ignition Switch, Lock Cylinder And Door Lock Cylinders + Keys $195,
#2947486 Ignition Switch 70-74 $155,
#2947488 Ignition Key Buzzer Switch # All 1970-75 $55,
#3695087 65-73 C-Body Electric Door Lock Latch Solenoid, For Left Front Or Right Rear Door $125,
#2857486 67-8 Imperial Vacuum Brake Release + Back Up Lamp Column Mounted Reverse Switch $125,
#3488716 72-3 New Yorker 4-Gang Power Window Switch $145,
#3488216 1972 C-Body Station Wagon Power Tailgate Window Switch $50,
#3488623 72-3 Polara And Fury 2-Speed Wiper Switch $55,
Sign up for our email blast to get exclusive offers and discounts!
https://www.tonysparts.com/subscribe
Check Out Our New Webstore at Check Out Our New Webstore at
tonysparts.com]http://tonysparts.com]tonysparts.com
302-398-0821,
contact@tonysparts.com
Tonys Parts
Harrington Delaware 19952
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: TONY_DAGOSTINO] #3056322
07/05/22 02:43 PM
07/05/22 02:43 PM
DELAWARE
DELAWARE
All NOS Horn Related Parts:
#2808868 Low Note Horn (Different Then Assy Line) Spartan $75,
#2926327 1969-70 Horn Relay $50,
#3513211 71-74 Horn Relay $50,
#3579204 3513206 71-74 Horn Relay / Key Buzzer $50,
#3764643 1974-77 C-Body Horn Relay $30,
302-398-0821,
Tonys Parts
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: TONY_DAGOSTINO] #3056335
07/05/22 02:50 PM
07/05/22 02:50 PM
DELAWARE
DELAWARE
All NOS Mechanical Parts:
#2852175 Large 7290 U-Joint, says “Detroit” $275,
#2536121 Rubber Motor Mount Insulator 66-72 B+C + 70-4 E-Body $135,
#2808441 + 2203116 61-69 PCV Valve with Cap And Retainer $45,
#2808441 61-69 PCV Valve $25,
#2098058 + 2098244 1962-72 Point + Condenser Set For Single Point Distributor $15,
#2098244 62-72 Point Set, For Single Point Distributor s/a 2098057 2098244 Contact Points $10,
#3420751 Mopar Spark Plugs #66P, 318 Application Will Also Work In 340 or 273 $65set,
#3683948 69-73 318 Heat Riser Repair Kit $85,
#3514468 S/A 3621286 67-71 383 2-BBL Carter Carburetor Rebuild Kit $25,
#3621286 67-71 383 Engine 2-BBL Carter Carburetor Rebuild Kit $25,
302-398-0821,
Tonys Parts
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: TONY_DAGOSTINO] #3056340
07/05/22 02:56 PM
07/05/22 02:56 PM
DELAWARE
DELAWARE
All NOS A/C Related Parts:
#2587564 66-67 A/C Vacuum Electric Switch $375,
#3502126 Most 68+ Newer Dash A/C Vacuum Electric Switch for Std A/C, (Need Old Harness for Use in 68-70 B-Body) $110,
#2936488/2936490/3441885 A/C Water Valve + Brackets 69-70 C-Body, 1971 B-Body W/O A.T.C. $125,
#3502714 1972-3 C-Body 74-80 Truck Operated A/C Water Valve, shelfwear $85,
#2837163 A/C Compressor Clutch 2-Groove Pulley Assembly + Coil $275,
#2837163 69-74 A/C Compressor Clutch 2 Groove Pulley Assy W/O Coil $175,
#2097105 60-72 A/C Compressor Clutch Field Coil, 1-3/8″ x 4-13/16″, use with 5 1/8″ OD Clutch $300,
#3502016 71-73 A/C Pressure Switch $55,
#3555995 61-74 A/C Pressure Valve, In Compressor $100,
302-398-0821,
Tonys Parts
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: TONY_DAGOSTINO] #3056347
07/05/22 03:00 PM
07/05/22 03:00 PM
DELAWARE
DELAWARE
NOS
#3586845 72-3 C-Body Left Remote Mirror $75
#3586843 is On Mirror Base
302-398-0821,
Tonys Parts
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: TONY_DAGOSTINO] #3056352
07/05/22 03:02 PM
07/05/22 03:02 PM
DELAWARE
DELAWARE
All NOS Gauges:
#2927225 69-73 Chrysler Fuel Gauge $75,
#2927045 1969-73 Fury and 1971-73 Polara Monaco Fuel Gauge $50,
#2984238 1969-73 Fury 1971-73 Polara Monaco Temp Gauge $35,
#2985513 71-3 Imperial Temp/Fuel Gauge $90,
302-398-0821,
Tonys Parts
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: moparts] #3056436
07/05/22 07:09 PM
07/05/22 07:09 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
I have a Good dash with wiring removed from a 1973 Imperial for sale $400.
I will not ship this must be picked up in Huntington Station NY 11746,
or I can deliver it to Chryslers at Carlisle July 14, 15, 16. OR possible delivery in NY, NJ, Conn for gas and tolls.
PM me if your interested
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: LTLBEE] #3064947
08/03/22 02:41 PM
08/03/22 02:41 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
One NOS set of 4, wide flute, GE headlight bulbs for Mopars with 4 headlights. There are two #4002 and two #4001. The 4002 bulbs were made in Canada and are in original CHYCO boxes and the 4001 were made in the USA and are in MOPAR original boxes. They are new old stock and the lenses have the words "GENERAL ELECTRIC" molded in them at the 6 o’clock position and the numbers “1” & “2” at the 12 o’clock position. All bulbs are tested before listing. The price is $320.00 plus shipping. Payment by USPS money order.
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: moparts] #3065788
08/06/22 02:34 PM
08/06/22 02:34 PM
Arizona
sixpakjoe Offline
sixpakjoe  Offline
Arizona
Mopar Oil Filter Adapter
90 degree type. Fits 273, 318, 340 and 360 engines. Will work with A, B, C and E Body cars. Original part in excellent condition. $40 - Pickup preferred, as shipping would be too expensive. Contact Joe at sixpakjoe@cox.net.
20220806_104502 (1).jpg (277 downloads)
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: sixpakjoe] #3068798
08/17/22 10:22 AM
08/17/22 10:22 AM
gtxblu Offline
gtxblu  Offline
I have a rock solid rust free 1966 chrysler new yorker deck lid for sale. Stored many years. $75.00. 1-734-775-0738. Located 20 miles north of toledo.
73 NEWPORT/NEW YORKER NOS PARKING LIGHT [Re: gtxblu] #3071398
08/25/22 03:37 PM
08/25/22 03:37 PM
BRIDGEWATER, CT.
WINGNUT Offline
WINGNUT  Offline
BRIDGEWATER, CT.
NOS, FITS EITHER SIDE. $56 SHIPPED IN U.S. No Paypal. U.S. money order only. VEIGHTPETE@GMAIL.COM
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: moparts] #3072442
08/29/22 05:55 PM
08/29/22 05:55 PM
NJ
moparply Offline
moparply  Offline
NJ
Original Jack Hook in excellent condition, part number 2533420, $30
You will not find one in better condition. Original paint! Great price on a part from over 50+ years ago!
LAST OF THE REAL ONES
Email Kenei@comcast.net
Re: For Sale - Mopar Full Size - Parts - 3rd Quarter [Re: moparts] #3073376
09/01/22 07:33 PM
09/01/22 07:33 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
As summer nears to a close we are having a clearance sale until the items below are sold out. First come, first serve, shipping charges will apply. Clearance list attached.
Payment by check, money order, or Paypal Friends and Family.
For more details or questions, email us directly at mail.dixierestorationparts@gmail.com.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Pair 1966 Fury 14" Wheelcovers [Re: twodoorpost] #3078487
09/18/22 04:04 PM
09/18/22 04:04 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Two used '66 Fury 14" wheelcovers. These are driver quality caps with some dings and blemishes. $40.00 picked-up near Freehold, NJ 07728. If you need shipping, send me your zip code and I'll figure it out. Sorry, will only ship to lower 48 States.
Best response is by Moparts PM.
Set of 1973 Chrysler Wheel Covers 15" [Re: Powerflow] #3078903
09/19/22 10:43 PM
09/19/22 10:43 PM
Between Houston & Galveston TX
Satilite73 Offline
Satilite73  Offline
Driver quality, not perfect, but not roached out either. A few dings, and one was painted incorrectly when new, but not noticeable unless you're right on it..
Use 'em for your driver or for your mancave.
$60 plus shipping. Will NOT ship out of country, only lower 48.
If you're in the Houston area and can pick them up, and save me from shipping, will offer a discount.
PM me here or email me at satilite73@yahoo.com
Will be posting other covers I have as I get more pictures. Thanks!
[Linked Image][Linked Image]
John
Imagine a '73 Satellite Wagon picture here. 😁
1971 Chrysler Newport Parking Lights [Re: Satilite73] #3078911
09/19/22 10:59 PM
09/19/22 10:59 PM
Satilite73 Offline
Satilite73  Offline
Set of lights pulled from a '71 Newport I used to own. I originally thought these were the ones I pulled from a truck, but was corrected by a member here (thanks!). 20 yrs on, the memory fades........ blush
The housings are in very good condition, not all rotted out as is so common to see. The lenses are driver quality, I few chips, but no cracks. Wires still retain their factory connectors, nothing has been cut.
I do not know if they fit other years.
Need them gone, $15.00 plus shipping. Will not ship out of country, sorry.
PM me here, or email me at satilite73@yahoo.com Thank you!
John
Fury headlight bezels [Re: Satilite73] #3080199
09/24/22 09:44 AM
09/24/22 09:44 AM
northeast
bfly Offline
bfly  Offline
northeast
Original factory driver quality Fury headlight bezels
Nice solid shape, no tears
35 plus shipping
Parts are in NY pm me here at site, more pics available
