E Body 4 speed shifter
#3078300
09/18/22 08:20 AM
09/18/22 08:20 AM
Posts: 9,026 Rogue River, OR
Jeremiah
Rogue River, OR
Howdy,
I have a friend in town that is wanting to convert his originally equipped a230 3 speed 70 Challenger to a four speed. I have lots of A/B body Hurst shifter parts. Will the shifter mechanism swap over? I figured the mount, rods/levers and shift rods would be different.
Normally I would just order a complete setup however this fellow is retired and on a budget so I want to help him out using parts from the attic as much as possible.
Re: E Body 4 speed shifter
[Re: Alaskan_TA]
#3078314
09/18/22 08:46 AM
09/18/22 08:46 AM
Posts: 9,868 North Dakota
6PakBee
North Dakota
Just a question, does the three-speed use the piston grip handle or the round ball?
"Only the best and brightest"
[Re: 6PakBee]
#3078358
09/18/22 10:23 AM
09/18/22 10:23 AM
Jeremiah
Rogue River, OR
Just a question, does the three-speed use the piston grip handle or the round ball? It has a round stick with a black ball. I will have hime shoot me a pic to share.
[Re: Jeremiah]
#3078387
09/18/22 11:30 AM
09/18/22 11:30 AM
6PakBee
North Dakota
Thanks! I didn't know the '70 three speeds used the Inland box. I learned something this morning.
[Re: Sniper]
#3078429
09/18/22 12:41 PM
09/18/22 12:41 PM
Posts: 17,240 north of coder
moparx
a kid in high school did that on a chevy. [i can't recall the year or model] just left off the reverse rod. a blocker would be good to have, but i would have to study the mechanism to see if it could be feasible. i can't say how a pistol grip 4spd shifter would bolt up, or work on, a 230 transmission. there would more than likely need to be some trinkity work needed to make it mount and operate. i wouldn't think it wouldn't be anything major. however, it might be a ton easier to just wack off a chunk of the pistol grip handle, then weld on a triangle shape with the appropriate sizes holes for the 3spd inland shifter, then just bolt it on and go.
[Re: Jeremiah]
#3078496
09/18/22 03:42 PM
09/18/22 03:42 PM
Posts: 10,414 Rittman Ohio
fourgearsavoy
Rittman Ohio
You could use a 71-74 B body shifter and plate if you don't have an E body unit. I have used an earlier B shifter before on my E body extension but I made my own linkage from tubing and heim joints. It can be done on a budget and you probably have enough stuff in your stash to make it work. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Jeremiah]
#3078506
09/18/22 04:16 PM
09/18/22 04:16 PM
Posts: 40,855 Bend,OR USA
Cab_Burge
All the stock OEM4 speed E bodies I've seen had the Hurst pistol grip shifters. I remember a friend and fellow racer buying a Super Shifter 3 for his Challenger, I helped him install it, that was a pain and it didn't fit well  : rant:
[Re: moparx]
#3078514
09/18/22 04:36 PM
09/18/22 04:36 PM
Posts: 4,991 nowhere
Sniper
nowhere
a kid in high school did that on a chevy. [i can't recall the year or model] just left off the reverse rod. a blocker would be good to have, but i would have to study the mechanism to see if it could be feasible. i can't say how a pistol grip 4spd shifter would bolt up, or work on, a 230 transmission. there would more than likely need to be some trinkity work needed to make it mount and operate. i wouldn't think it wouldn't be anything major. however, it might be a ton easier to just wack off a chunk of the pistol grip handle, then weld on a triangle shape with the appropriate sizes holes for the 3spd inland shifter, then just bolt it on and go. Years ago, I was looking at a Mustang II Cobra that someone did the opposite of, used a three speed shifter on a 4 speed, Just poked the reverse rod thru the shifter boot so you could engage it by hand, lol. I passed on that car.
[Re: Cab_Burge]
#3078548
09/18/22 06:31 PM
09/18/22 06:31 PM
fourgearsavoy
Rittman Ohio
All the stock OEM4 speed E bodies I've seen had the Hurst pistol grip shifters. I remember a friend and fellow racer buying a Super Shifter 3 for his Challenger, I helped him install it, that was a pain and it didn't fit well  : rant: You do have to enlarge the hole in the floor slightly but there is no better H-pattern shifter for the money than a Super Shifter 3. I have had a few of them and currently have one in my Savoy and it shifts like butter. I was at a 3 day bracket race about 25 years ago and went 31 passes without missing a single gear all with a Super Shifter  Gus
[Re: Sniper]
#3078726
09/19/22 12:57 PM
09/19/22 12:57 PM
moparx
a kid in high school did that on a chevy. [i can't recall the year or model] just left off the reverse rod. a blocker would be good to have, but i would have to study the mechanism to see if it could be feasible. i can't say how a pistol grip 4spd shifter would bolt up, or work on, a 230 transmission. there would more than likely need to be some trinkity work needed to make it mount and operate. i wouldn't think it wouldn't be anything major. however, it might be a ton easier to just wack off a chunk of the pistol grip handle, then weld on a triangle shape with the appropriate sizes holes for the 3spd inland shifter, then just bolt it on and go. Years ago, I was looking at a Mustang II Cobra that someone did the opposite of, used a three speed shifter on a 4 speed, Just poked the reverse rod thru the shifter boot so you could engage it by hand, lol. I passed on that car. that was a "reverse lock out" shifter.
[Re: 71GTX471]
#3078889
09/19/22 09:19 PM
09/19/22 09:19 PM
Jeremiah
Rogue River, OR
Interesting info. This car was a /6 3-speed and converted over to a 360 in the late 90's. It still wear the original fk5 paint job which is cool.
[Re: Cab_Burge]
#3078890
09/19/22 09:21 PM
09/19/22 09:21 PM
Jeremiah
Rogue River, OR
Some BB bell housing have both patterns, some do not He said the bell has both patterns so we are good to go..I hope
[Re: fourgearsavoy]
#3079062
09/20/22 01:19 PM
09/20/22 01:19 PM
Cab_Burge
The A and B body shifters are way different than the E body shifters which are mounted behind the trans crossmember, the shifter rods have to reach a lot longer forward than both the A and B body shifters do  Those rods would bend and straighten up after hard shifting them for a while, a real pain to maintain  I'm sure they help Hurst come up with making the Ram Rod and Super Shifters
[Re: Cab_Burge]
#3079496
09/22/22 04:26 AM
09/22/22 04:26 AM
Jeremiah
Rogue River, OR
You have me thinking I should use the truck shifter with the appropriate adapter and build my rods like Gus mentuoned. That is probably the most economical way to make it happen.
Not sure if he will end up with a pistol grip shifter handle. They are stupid money and I don't know if there is budget for a $250+ shifter handle.
