Grease? Or what for electrical connections #3077911
09/16/22 07:56 PM
09/16/22 07:56 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Going thru my van connections trying to hunt down a ‘no bus’ problem and was thinking of something to put in the connections that could help make the contacts better. Is there such a product?
Re: Grease? Or what for electrical connections [Re: cudaman1969] #3077927
09/16/22 08:28 PM
09/16/22 08:28 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I would think you could use dielectric grease shruggy
Facts are stubborn things.
Re: Grease? Or what for electrical connections [Re: larrymopar360] #3077930
09/16/22 08:31 PM
09/16/22 08:31 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Dielectric grease does not make a "better" connection. What it does is take an acceptable connection and protect it from future corrosion.
Re: Grease? Or what for electrical connections [Re: 6PakBee] #3077938
09/16/22 08:36 PM
09/16/22 08:36 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I'm assumed that's what he's was asking. Avoiding corrosion for better connection shruggy But now that I read it again, I guess not.
Re: Grease? Or what for electrical connections [Re: larrymopar360] #3077953
09/16/22 09:28 PM
09/16/22 09:28 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Deoxit is what you want.
Re: Grease? Or what for electrical connections [Re: Sniper] #3077961
09/16/22 10:03 PM
09/16/22 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A good article to read wink LINKY
Re: Grease? Or what for electrical connections [Re: TJP] #3078052
09/17/22 11:17 AM
09/17/22 11:17 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Interesting.
Re: Grease? Or what for electrical connections [Re: larrymopar360] #3078061
09/17/22 11:38 AM
09/17/22 11:38 AM
nowhere
nowhere
I would not use conductive grease in an automotive application, especially any multi pin connection, too much opportunity for inducing shorts.
Re: Grease? Or what for electrical connections [Re: cudaman1969] #3078073
09/17/22 12:13 PM
09/17/22 12:13 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Stabilant 22A This was used on the job I used to work at. It's expensive, but you don't use a lot.
https://www.youtube.com/watch?v=3JvoKBMceXA
Re: Grease? Or what for electrical connections [Re: EW1BH27] #3078114
09/17/22 02:34 PM
09/17/22 02:34 PM
moparx Offline
moparx  Offline
i use the common di-electric grease available almost everywhere.
i have been doing this for over 40 years, and have had zero problems caused by doing this.
remember, this is strictly in an automotive environment, and the only salt encounter is with winter road "maintenance", splashing on some under body connections.
my personal experience playing with these things for almost 60 years now.
your mileage will vary.
beer
Re: Grease? Or what for electrical connections [Re: moparx] #3078189
09/17/22 07:08 PM
09/17/22 07:08 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
CRC 2-26 electrical spray cleaner & lubricant.
Re: Grease? Or what for electrical connections [Re: 71GTX471] #3078211
09/17/22 09:06 PM
09/17/22 09:06 PM
fredericksburg,va
fredericksburg,va
Thanks to all the answers so far
Re: Grease? Or what for electrical connections [Re: cudaman1969] #3078494
09/18/22 04:26 PM
09/18/22 04:26 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
On a single bullet or packard connector, I have used Noalox, its conductive. I agree on a previous post, don't use it on a multi-connector because of a short possibility. Dielectric grease is good to stop corrosion and after cleaning the terminals, a good way to make the connection again.
https://www.idealind.com/us/en/shop/30-026.html
1972 Dodge Challenger
Re: Grease? Or what for electrical connections [Re: cudaman1969] #3078748
09/19/22 02:49 PM
09/19/22 02:49 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
You didn't ask this but the nobus a lot of times means the computer is bad. I have been through a couple already on my 2002 van. Coil drivers in particular are bad about burning up. If you take the computer off the firewall and get a faint whiff of something burned, it is time to replace for sure.
Re: Grease? Or what for electrical connections [Re: mgoblue9798] #3078771
09/19/22 03:41 PM
09/19/22 03:41 PM
fredericksburg,va
fredericksburg,va
That’s what I’m thinking too thanks
Re: Grease? Or what for electrical connections [Re: cudaman1969] #3078835
09/19/22 06:52 PM
09/19/22 06:52 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Wd40 makes an outstanding contact cleaner. I follow up with SuperLube's contactor corrosion preventer. If you choose to go this route, read the label on the SuperLube, they have several products in very similar packages.
