More Caterpillar Mayhem #3077347
09/14/22 10:19 PM
09/14/22 10:19 PM
Downtown Roebuck Ont
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Any suggestions on which JB Weld to use for this application?
Kevin
Re: More Caterpillar Mayhem [Re: Twostick] #3077348
09/14/22 10:26 PM
09/14/22 10:26 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by Twostick
Any suggestions on what rod to Weld with for this application?
Kevin
With the way the head of the ALLEN bolt is bent I can't think of any JB Weld that would ever be strong enough. Looks to me welding might(???) work but replacing the part and bolt is the only solution IMO.
If you want to try JB Weld, as you asked, the original long cure JB Weld epoxy is (according to JB Weld) is the strongest when finally cured.
https://www.jbweld.com/our-videos
Re: More Caterpillar Mayhem [Re: A12] #3077356
09/14/22 10:42 PM
09/14/22 10:42 PM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Kevin
The adjuster isn't actually bent. It's got a foot that swivels. Just happened to land that way when I set it down. It's an exhaust rocker for a 3406E/C15 Cat. You think Hemi valve train parts are $$$.
They are fairly famous for breaking which astonishes me given it's almost an inch thick solid $teel and these run almost nothing for spring pressure, 55 closed 180 open.
It's a paper weight now. Lol
Kevin
Re: More Caterpillar Mayhem [Re: Twostick] #3077363
09/14/22 10:54 PM
09/14/22 10:54 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Seems they have a small wall thickness & it's cast iron.
Re: More Caterpillar Mayhem [Re: Twostick] #3077366
09/14/22 11:12 PM
09/14/22 11:12 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Oops is that a swivel tappet and that's why it looks like an Allen bolt head (bent head)? blush
Re: More Caterpillar Mayhem [Re: A12] #3077368
09/14/22 11:22 PM
09/14/22 11:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This looks like an improved version of the same part number 1085896, but I may be wrong? They are asking $110 for it on ebag.
Also there's one on ebag that shows it for $32 but when you go to the link it's listed for $50???
https://www.ebay.com/itm/2645989487...ustomid=aa86f19ee61d171a384c92bc7e6e16fa
Re: More Caterpillar Mayhem [Re: A12] #3077443
09/15/22 09:39 AM
09/15/22 09:39 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Cat is pretty proud of their's.
Kevin
Re: More Caterpillar Mayhem [Re: A12] #3077479
09/15/22 11:38 AM
09/15/22 11:38 AM
moparx Offline
moparx  Offline
[url=https://www.ebay.com/itm/264598948774?var=0&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338590836&toolid=10044&customid=aa86f19ee61d171a384c92bc7e6e16fa][/url]
this work ? the add says $32.50 with $50.00 crossed out.
beer
Re: More Caterpillar Mayhem [Re: moparx] #3077572
09/15/22 05:06 PM
09/15/22 05:06 PM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
You installed this yourself ? I looked at the bill and it doesn’t look like they did the labour but maybe that was a different invoice ? Which prefix of cat have you got I’m wondering. Did this make a bunch of noise when it broke or how did you notice something was wrong. I have a cat in my truck and I’m interested to know what happened here.
Re: More Caterpillar Mayhem [Re: BleedDodge] #3077581
09/15/22 05:39 PM
09/15/22 05:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Kevin
I'm thinking this is a joke. Regardless, I'd call the good folks at Rocker Arms Unlimited and see what the they have to say. They just repaired an Isky adjustable rocker for me.
Re: More Caterpillar Mayhem [Re: Twostick] #3077671
09/15/22 09:23 PM
09/15/22 09:23 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Cat definitely makes the money on the back end of the sale.. We're assigned a parts rep when we buy new machines..We have to go through him to get a better price on the needed parts.. The dealership parts counter people will absolutely rake you over the coals if you run it through there... twocents
Re: More Caterpillar Mayhem [Re: screamindriver] #3077713
09/16/22 03:28 AM
09/16/22 03:28 AM
Guitar Jones Offline
$270 for a single rocker arm and a core charge on top of that? Even though that's Canadian money it's still crazy.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: More Caterpillar Mayhem [Re: Guitar Jones] #3077720
09/16/22 06:55 AM
09/16/22 06:55 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
CAT = Can't Afford This... lol
Kevin
Re: More Caterpillar Mayhem [Re: BleedDodge] #3077721
09/16/22 06:57 AM
09/16/22 06:57 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Yes, the install was over and above. Took an hour plus the service call. About another $300.
Kevin
Re: More Caterpillar Mayhem [Re: Twostick] #3077975
09/16/22 10:53 PM
09/16/22 10:53 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
[ CAT = Can't Afford This... lol Kevin
Made me think of BMW = Bring More Wallets beer
Re: More Caterpillar Mayhem [Re: Twostick] #3078264
09/18/22 01:31 AM
09/18/22 01:31 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Kevin
It's a 3406E. 1LW prefix.
Kevin
Re: More Caterpillar Mayhem [Re: PhillyRag] #3078265
09/18/22 01:40 AM
09/18/22 01:40 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Yes, it's cast. Not sure what I was thinking other than the roller end is machined all sides and looks like billet.
Those casting marks do give it away tho...
Kevin
Re: More Caterpillar Mayhem [Re: Guitar Jones] #3078266
09/18/22 01:43 AM
09/18/22 01:43 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Welcome to the wonderful world of Caterpillar.
Makes Gen II Hemi stuff look economical...
Kevin
Re: More Caterpillar Mayhem [Re: Twostick] #3078268
09/18/22 02:24 AM
09/18/22 02:24 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Kevin
I think I'd at least give the JB Weld a try laugh2 laugh2
Re: More Caterpillar Mayhem [Re: Twostick] #3078392
09/18/22 12:43 PM
09/18/22 12:43 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
That fracture looks like a “fatigue crack” that started at a “stress concentration edge” that the original part designers never should allowed to stay in the final design.
The “improved part” from the ebay ad does look superior.
If you absolutely had to repair that - braze it - not weld it or JB Weld Epoxy.
Prior to brazing add steel stiffeners above and below as clearance allows.
Instead of throwing the broken part away,
package it up and mail it to:
Department of Mechanical Engineering
Duke University
Durham NC
attn: Failure Analysis Class
Add a short note saying that you suggest
a 4th year engineering student take on what caused this part to fail for their end of class project,
and that many hundreds of these parts are/were in service around the USA.
( Students are always looking for a worthwhile failure to investigate)
Both CAT and Cummins hire 2-3 Duke students per year,
although the majority of Duke mechanical engineering students are Navy ROTC
(and us taxpayers pay their +$75,000 year tuition)
