More Caterpillar Mayhem
#3077347
09/14/22 10:19 PM
09/14/22 10:19 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Any suggestions on which JB Weld to use for this application?
Kevin
Re: More Caterpillar Mayhem
[Re: Twostick]
#3077348
09/14/22 10:26 PM
09/14/22 10:26 PM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
Any suggestions on what rod to Weld with for this application?
Kevin With the way the head of the ALLEN bolt is bent I can't think of any JB Weld that would ever be strong enough. Looks to me welding might(???) work but replacing the part and bolt is the only solution IMO. If you want to try JB Weld, as you asked, the original long cure JB Weld epoxy is (according to JB Weld) is the strongest when finally cured. https://www.jbweld.com/our-videos
[Re: A12]
#3077356
09/14/22 10:42 PM
09/14/22 10:42 PM
Twostick
Still wishing...
Still wishing...
Kevin With the way the head of the ALLEN bolt is bent I can't think of any JB Weld that would ever be strong enough. Looks to me welding might(???) work but replacing the part and bolt is the only solution IMO. The adjuster isn't actually bent. It's got a foot that swivels. Just happened to land that way when I set it down. It's an exhaust rocker for a 3406E/C15 Cat. You think Hemi valve train parts are $$$. They are fairly famous for breaking which astonishes me given it's almost an inch thick solid $teel and these run almost nothing for spring pressure, 55 closed 180 open. It's a paper weight now. Lol Kevin
[Re: BleedDodge]
#3077581
09/15/22 05:39 PM
09/15/22 05:39 PM
Posts: 8,863 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Kevin I'm thinking this is a joke. Regardless, I'd call the good folks at Rocker Arms Unlimited and see what the they have to say. They just repaired an Isky adjustable rocker for me.
[Re: screamindriver]
#3077713
09/16/22 03:28 AM
09/16/22 03:28 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
$270 for a single rocker arm and a core charge on top of that? Even though that's Canadian money it's still crazy.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#3077720
09/16/22 06:55 AM
09/16/22 06:55 AM
Twostick
Still wishing...
Still wishing...
$270 for a single rocker arm and a core charge on top of that? Even though that's Canadian money it's still crazy. CAT = Can't Afford This... lol Kevin
[Re: BleedDodge]
#3077721
09/16/22 06:57 AM
09/16/22 06:57 AM
Twostick
Still wishing...
Still wishing...
You installed this yourself ? I looked at the bill and it doesn’t look like they did the labour but maybe that was a different invoice ? Which prefix of cat have you got I’m wondering. Did this make a bunch of noise when it broke or how did you notice something was wrong. I have a cat in my truck and I’m interested to know what happened here. Yes, the install was over and above. Took an hour plus the service call. About another $300. Kevin
[Re: Twostick]
#3078264
09/18/22 01:31 AM
09/18/22 01:31 AM
Twostick
Still wishing...
Still wishing...
You installed this yourself ? I looked at the bill and it doesn’t look like they did the labour but maybe that was a different invoice ? Which prefix of cat have you got I’m wondering. Did this make a bunch of noise when it broke or how did you notice something was wrong. I have a cat in my truck and I’m interested to know what happened here. Yes, the install was over and above. Took an hour plus the service call. About another $300. Kevin It's a 3406E. 1LW prefix. Kevin
[Re: PhillyRag]
#3078265
09/18/22 01:40 AM
09/18/22 01:40 AM
Twostick
Still wishing...
Still wishing...
Seems they have a small wall thickness & it's cast iron. Yes, it's cast. Not sure what I was thinking other than the roller end is machined all sides and looks like billet. Those casting marks do give it away tho... Kevin
[Re: Guitar Jones]
#3078266
09/18/22 01:43 AM
09/18/22 01:43 AM
Twostick
Still wishing...
Still wishing...
$270 for a single rocker arm and a core charge on top of that? Even though that's Canadian money it's still crazy. Welcome to the wonderful world of Caterpillar. Makes Gen II Hemi stuff look economical... Kevin
[Re: Twostick]
#3078268
09/18/22 02:24 AM
09/18/22 02:24 AM
A12
N.E. OHIO, USA
$270 for a single rocker arm and a core charge on top of that? Even though that's Canadian money it's still crazy. Welcome to the wonderful world of Caterpillar. Makes Gen II Hemi stuff look economical... Kevin I think I'd at least give the JB Weld a try
