Re: Grease? Or what for electrical connections
[Re: larrymopar360]
#3077930
09/16/22 08:31 PM
09/16/22 08:31 PM
Posts: 10,723 North Dakota
6PakBee
North Dakota
Dielectric grease does not make a "better" connection. What it does is take an acceptable connection and protect it from future corrosion.
[Re: 6PakBee]
#3077938
09/16/22 08:36 PM
09/16/22 08:36 PM
Posts: 15,887 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Dielectric grease does not make a "better" connection. What it does is take an acceptable connection and protect it from future corrosion. I'm assumed that's what he's was asking. Avoiding corrosion for better connection But now that I read it again, I guess not.
Facts are stubborn things.
[Re: EW1BH27]
#3078114
09/17/22 02:34 PM
09/17/22 02:34 PM
Posts: 19,421 north of coder
moparx
i use the common di-electric grease available almost everywhere. i have been doing this for over 40 years, and have had zero problems caused by doing this. remember, this is strictly in an automotive environment, and the only salt encounter is with winter road "maintenance", splashing on some under body connections. my personal experience playing with these things for almost 60 years now. your mileage will vary.
[Re: cudaman1969]
#3078494
09/18/22 04:26 PM
09/18/22 04:26 PM
Posts: 1,234 Chicago, IL
PLUM_72
Chicago, IL
On a single bullet or packard connector, I have used Noalox, its conductive. I agree on a previous post, don't use it on a multi-connector because of a short possibility. Dielectric grease is good to stop corrosion and after cleaning the terminals, a good way to make the connection again. https://www.idealind.com/us/en/shop/30-026.html
1972 Dodge Challenger
[Re: mgoblue9798]
#3078771
09/19/22 03:41 PM
09/19/22 03:41 PM
Posts: 8,275 fredericksburg,va
cudaman1969
fredericksburg,va
You didn't ask this but the nobus a lot of times means the computer is bad. I have been through a couple already on my 2002 van. Coil drivers in particular are bad about burning up. If you take the computer off the firewall and get a faint whiff of something burned, it is time to replace for sure. That’s what I’m thinking too thanks
