Re: 2-1/8 Headers on '68 Coronet
[Re: cgall]
#3077663
09/15/22 09:15 PM
09/15/22 09:15 PM
Posts: 9,847 MI, usa
dvw
MI, usa
The 62-65 engine is mounted further forward. I'm assuming #7 and #8 tubes go thru the fender well with slip on collectors.. I run what I believe is the same header. Hooker 5320. We've run 4 sets of these on 3 different cars. Two of the cars had the motor moved back close to the 66-70 location. The right side has always fit. The left side depends on how far back the engine is. One set the #7 tube had to be raised to go over the steering shaft. Two sets fit perfect. One set the #1 tube was modified slightly. Doug
[Re: cgall]
#3077693
09/15/22 10:36 PM
09/15/22 10:36 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
The K members are different between 1963 to 1965, 1966 to 1971 are the same. I'm putting a 1967 B body K member in my 1963 Plymouth Fury for better weight distribution, better header selection and so on
[Re: AndyF]
#3077887
09/16/22 05:24 PM
09/16/22 05:24 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I used 2 1/8" for the last set I built - 900HP 550+". 7K. And I used a smallish merge collector. Picked it up over what was on it.
Unless that will regularly see 5-6000 RPM, 2" is too big. The trend is smaller with port matching the headers to the heads as well. Velocity.
