Get performance trends engine analyzer, it will generate an advance curve with various fuels including alcohol. For example I just used it on the dyno with a 512 mopar, with Holley electronic fuel injection. The Holley stock timing maps basically go to full advance after 2,500rpm. Engine did not like that much advance on the dyno. Plugged engine into the program, generated advance curve, used that curve into the Holley computer timing map and it made 615 ft. lbs torque and 515 HP I have done this multiple times with various engines including supercharged engines, it is easy and it really works. On my dyno anyway the predicted timing curve is usually a couple degrees from the max HP on the first pull.
