70 cuda window crank #3076882
09/13/22 11:29 AM
09/13/22 11:29 AM
central il.
second 70 Offline OP
central il.
The knobs on my window crank have crumbled due to age. I ordered a replacement but they're not a true match. Is the broken one factory and if so can you just get replacement knobs? Thanks Mike
Re: 70 cuda window crank [Re: second 70] #3076924
09/13/22 01:49 PM
09/13/22 01:49 PM
moparx Offline
moparx  Offline
as the knobs are riveted to the handle, way back in the day, i had accumulated a bunch of them because they would bind up and break the rivet.
i think that was because we just cranked on them in a haphazard way, and with the slightest bind, the rivet was the weakest link.
we sold lots of those handles back in my junkyard ownership days, 1972-1984.
over the years, the ones i had squirreled away became missing............
i don't believe the knobs are sold separately.
beer
Re: 70 cuda window crank [Re: moparx] #3078641
09/19/22 08:04 AM
09/19/22 08:04 AM
northeast
bfly Offline
bfly  Offline
northeast
I may have one,let me check and get back to you
Re: 70 cuda window crank [Re: second 70] #3078644
09/19/22 08:52 AM
09/19/22 08:52 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Here's an old original. This should give an idea, I guess it's +/- a bit.
Re: 70 cuda window crank [Re: EW1BH27] #3078685
09/19/22 11:08 AM
09/19/22 11:08 AM
central il.
central il.
The difference is on the bolt end. It hard to see but the replacement is more square on the end and the one I took off has a taper to it. I have no idea if the broken one is factory or not. Not a numbers show car so no big deal but the chrome is great on them and if factory might be worth keeping.
Re: 70 cuda window crank [Re: second 70] #3078729
09/19/22 02:04 PM
09/19/22 02:04 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
I see what you mean, thanks for clearing that up. All my factory ones have that "taper" on the bolt end.
Re: 70 cuda window crank [Re: EW1BH27] #3078738
09/19/22 02:23 PM
09/19/22 02:23 PM
central il.
central il.
Thanks, That's what I thought.
