Re: SB race block and heads ID?
[Re: rickraw]
#3076651
09/12/22 04:57 PM
09/12/22 04:57 PM
Posts: 161 W. Pa
usp4u
W. Pa
X or R blocks will have a designator cast into the RT front. X R R1 R1A R2 R3 R4 R5 The casting #s are virtually useless given the amounts of variations that were available. A couple of my R blocks have actual "P" part numbers die stamped on them, but I dont recall where at. There are a few variants of W5s....post some more pics of the heads. Particularly the rocker lay-out and the ends of the heads. The world of R blocks is a total rabbit hole. Chrysler screwed up more than a few. Ive seen them with undrilled oil galleys. I currently have 5 of them, including one of the ones that got sold with the wrong cam tunnel
[Re: usp4u]
#3076662
09/12/22 05:42 PM
09/12/22 05:42 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Ryan Johnson's web page used to have a lot of good info about the different blocks. I have an R1 59* and it is an oddball because it takes the 340 oil pan where most take the 360.
There is a web archive of his FAQ page that has some info.
https://web.archive.org/web/20050206201421/http://shadydellspeedshop.com/faq.htm
68 Barracuda Formula S 340
[Re: AndyF]
#3076754
09/12/22 10:07 PM
09/12/22 10:07 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Okay, I'll look for the X. I was told by the owner that it was an R block but the part number didn't match up. The owner said it was an R block with W9 heads but I'm thinking now that it is an X block with W5 heads. No guessing about the heads, they say W5 right on them. Block will have a huge X on the left front side( if looking at it from the front of the car) if it’s an X block. Otherwise it’s just a 318. The X and 318 do both come with same bore size, 3.91
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
