rear end swap #3076297
09/11/22 01:21 PM
09/11/22 01:21 PM
K
KOS Offline OP
KOS  Offline OP
K
Hey guys do you think 70 b body to 72 e body rear swap is possible without changing wheel backspacing?I believe there is only slightly more than 1" difference in length.who know exactly or has ever done something like this before.thx in advance.
Re: rear end swap [Re: KOS] #3076300
09/11/22 01:33 PM
09/11/22 01:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The spring perch centers are 2" different.
I did it years ago by using Dr. Diff's 1" offset kit.
It was a bolt in deal.
Re: rear end swap [Re: Alaskan_TA] #3076350
09/11/22 04:37 PM
09/11/22 04:37 PM
K
KOS Offline OP
KOS  Offline OP
K
Nice and thx for the info didn't know they offered such a kit.....what about overall length and wheel spacing?thats my biggest concern.
Re: rear end swap [Re: KOS] #3076354
09/11/22 05:09 PM
09/11/22 05:09 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Guess that depends on how much clearance you have now. Those old Mopar bodies had a lot of allowable body tolerances from car to car going down the same assembly line. I'd measure the clearance you have now, and subtract the difference from your current clearance. Back in the old days, you waned at least 3/4" clearance between the widest point on the tire to the closest point on the body, inside and out.
Re: rear end swap [Re: poorboy] #3076568
09/12/22 01:20 PM
09/12/22 01:20 PM
moparx Offline
moparx  Offline
and don't forget to measure both sides.
it is very common to find 1/2" difference in the tub width to quarter panel, right and left.
also check drum mounting surface to spring edge. that distance can be different as well.
these measurements pertain to cars that haven't been crashed. if crash [or rust] repaired, these points of measurement can be better or worse, depending on the skills of the person doing the repair[s].
beer
Re: rear end swap [Re: KOS] #3076726
09/12/22 09:12 PM
09/12/22 09:12 PM
The early (pre 1971) B body 8 3/4 rear ends are 2.0 inches narrower than the 1970 and up E body 8 3/4, as already mentioned the E body leaf spring are not the same width as the early (pre 1971) B bodies are.
E body leaf springs are angle from the front eye to the rear shackle also scope shruggy work
As far as the offset on the wheels and reusing those wheels and same size tires make sure they will have sufficient clearances on the inside, especially on the front inside to the leaf springs scope
Re: rear end swap [Re: Cab_Burge] #3076965
09/13/22 03:50 PM
09/13/22 03:50 PM
K
KOS Offline OP
KOS  Offline OP
K
ok guys thx
