Another MagnaLeak Bites the Dust
#3075768
09/09/22 12:05 PM
09/09/22 12:05 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Well, after my last fiasco with 500 leaking all over the place and nearly burning the car down, and now my 275 sprung a nice leak on our street strip car. I just pulled the 375 from the Duster to put in the Dart so we can go street racing tonight....None of the pumps are that old, but some of our cars also see street duty.....So, the pumps perform, but when that bearing goes out, be prepared for a big mess....And it does not seem like it takes that long for the bearings to go out...Its almost like you have to replace them every year or else...Suffer a big mess and loss of fuel.. ...
I would have put the rebuilt 500 in the car, but the big pump has bigger fittings and I would have to change all of them....The 375 has the same fittings as the 275....
My Aeromotive A1000....Almost 15 years, and still going.,...
Re: Another MagnaLeak Bites the Dust
[Re: Dragula]
#3075780
09/09/22 12:39 PM
09/09/22 12:39 PM
Posts: 10,019 MN
JERICOGTX
MN
I’ve had my Magnafuel 500 pump for 20 years, and I bought it used. It’s actually a MagnaFLOW pump before they changed names. Only have put in a shaft seal in all that time.
How much for your used pump???
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3075783
09/09/22 12:54 PM
09/09/22 12:54 PM
Posts: 4,671 On the parachute mount
n20mstr
How much for your used pump??? I have two 500's im about to put in the for sale section. One was in the car working fine, the other was a leaker that i took out. I bought the seal kit but never fixed it....
....BAD A$$ STREET CAR.....
[Re: justinp61]
#3075831
09/09/22 04:14 PM
09/09/22 04:14 PM
Posts: 16,470 On the run…
BloFish
On the run…
A friend had one, it began leaking two years after he got it. He switched to Aeromotive.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3075833
09/09/22 04:22 PM
09/09/22 04:22 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not as familiar with their pumps as I am the BG400 pumps but are you guys sure you are changing out everything required to rebuild them right. The BG400 pump owners weren’t.
[Re: pittsburghracer]
#3075834
09/09/22 04:26 PM
09/09/22 04:26 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
As I have said many times I have only had ONE leak over the last two decades. The one in the Savoy has been there for well over a decade now never an issue from it under the car getting pelted with crap on every burnout. These days we use Weldon stuff, just better products IMO but never had any real issues with Magnafuel pumps either. Have had some regulator problems over the years with them. That was what started the switch to Weldon was the regulators.
[Re: cudaman1969]
#3075844
09/09/22 04:46 PM
09/09/22 04:46 PM
BloFish
On the run…
“ I hope not China.” You can pretty much bet on that
[Re: cudaman1969]
#3075851
09/09/22 05:38 PM
09/09/22 05:38 PM
Al_Alguire
Las Vegas
Generally you want the bypass pressure higher than 15-20, usually 25-29 seems to be the "sweet" spot. Make sure you use adequately sized bypass hose dont try to make it smaller than they suggest. You can get a USA made bearing if you choose. The seal is almost a universal one for those styles pumps used by many. Also better seals can be found out there at a good bearing supply house. Ive bought a few over the years that were "bad" from folks,
[Re: Al_Alguire]
#3075876
09/09/22 07:11 PM
09/09/22 07:11 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Most of the guys I see at the track have their return lines into the fuel cell plumbed wrong too. The fuel is supposed to dump below the fuel, not on top of it creating bubbles.
#3075892
09/09/22 08:21 PM
09/09/22 08:21 PM
Al_Alguire
Las Vegas
Well mine all dump to the top of the cell..They also all have tubes to the bottom Just because they dump up top don't mean they stay that way on the cell. We also use a bleed line at the regulatorif its a fast car just in case
