Re: Slow progress
[Re: n20mstr]
#3075077
09/07/22 10:20 AM
09/07/22 10:20 AM
Posts: 4,064 Mo.
racerx
Mo.
That's a pretty small cell...you tow to the water box and on the return road? Yes we tow up and back, sometimes drive back. Plus im only racing 1/8 mile Got cha nice build.
Re: Slow progress
[Re: LA360]
#3080663
09/25/22 09:50 PM
09/25/22 09:50 PM
Posts: 4,670 On the parachute mount
n20mstr
Are you going over to Coil near Plug ignition Tony? I ran coil on plug even with the carburetor. Yes still going to be COP . I was using a Holley dominator ECU for nitrous control and the ignition. Now it’s 100% EFI
....BAD A$$ STREET CAR.....
Re: Slow progress
[Re: n20mstr]
#3082140
10/01/22 09:29 AM
10/01/22 09:29 AM
Posts: 8,160 Plymouth, MI
Blusmbl
Plymouth, MI
I'm loving the progress updates. It was already badass before, and is even more badass now!!
Re: Slow progress
[Re: Blusmbl]
#3082155
10/01/22 10:37 AM
10/01/22 10:37 AM
Posts: 4,031 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I'm loving the progress updates. It was already badass before, and is even more badass now!! Yes, exactly my thoughts. Tony, can you say what it dyno'd? Or what you think it'll make on spray? If not, I understand.
Re: Slow progress
[Re: HardcoreB]
#3082175
10/01/22 11:26 AM
10/01/22 11:26 AM
n20mstr
I'm loving the progress updates. It was already badass before, and is even more badass now!! Yes, exactly my thoughts. Tony, can you say what it dyno'd? Or what you think it'll make on spray? If not, I understand. I have petitioned a weight break for mopar bb in ultra street for a couple years now . I have raced as much as asked to get the weight breaks I asked for . Now , a BB mopar nitrous combination can weigh 50lbs less than a Pontiac , and 300lbs less than a BB Chevy . Now , that being said , let’s just say the field has been leveled ! The HP is GOOD and it will get 600? Of nitrous added I will say I was surprised to see the hp keep going up from 7300 to 7800 as most B1 combos seem to stop making HP at 7300
Re: Slow progress
[Re: n20mstr]
#3082218
10/01/22 12:56 PM
10/01/22 12:56 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
FWIW my last three B1 combos have made peak power well past 7300. Mylatest one peaks at 7800...But alot of Mopar guys just dont want to go there IMO
As Always bada$$ car and combo cant wait to see the end result.
Re: Slow progress
[Re: n20mstr]
#3102266
12/14/22 02:02 PM
12/14/22 02:02 PM
n20mstr
I'm loving the progress updates. It was already badass before, and is even more badass now!! Yes, exactly my thoughts. Tony, can you say what it dyno'd? Or what you think it'll make on spray? If not, I understand. I have petitioned a weight break for mopar bb in ultra street for a couple years now . I have raced as much as asked to get the weight breaks I asked for . Now , a BB mopar nitrous combination can weigh 50lbs less than a Pontiac , and 300lbs less than a BB Chevy . Now , that being said , let’s just say the field has been leveled ! The HP is GOOD and it will get 600? Of nitrous added I will say I was surprised to see the hp keep going up from 7300 to 7800 as most B1 combos seem to stop making HP at 7300 The current version of Ultra Street rules have been released. A BB 588 Mopar can be 2925 with up to a .050 jet in a direct port or 2875 with a plate (unlimited jet) . So its looking pretty good to run a BB Mopar.....IF you dont like money...
Re: Slow progress
[Re: n20mstr]
#3110326
01/09/23 12:52 PM
01/09/23 12:52 PM
n20mstr
Getting there , the black you see in the rust pits is Por15 . This was original paint on the frame rails , so there were some thin spots that had a little surface rust . Inside the rails look pretty good . This car has been garaged since 1983? So it’s pretty clean …..lol
Re: Slow progress
[Re: n20mstr]
#3110328
01/09/23 12:57 PM
01/09/23 12:57 PM
n20mstr
IF you wondering how i get the por15 to stay in only the rust pits.....i paint the area with por15, then come back next day and pass some 180 over it. It comes right off the "clean" metal but stays on the rust spots/pits. It seems to work ok, then i gave it two coats of epoxy primer and two coats of urethane primer.
