Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: Cab_Burge] #3073410
09/01/22 09:41 PM
09/01/22 09:41 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Originally Posted by Cab_Burge
I have seen many hotrodders leave their gas tanks have empty in the winter and summer for over 90 days and wonder why the engine doesn't run like normal, all pump fuel that I have heard has a limited shelf life of 90 days or less depending on how long that gas was in the tank at the station whiney
That’s basically what I have heard. I ALWAYS use stabil 360 in every tank for both toys and small power equipment.
I want my fair share
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: SomeCarGuy] #3073534
09/02/22 11:42 AM
09/02/22 11:42 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/927165/re-6-pack.html#Post927165
^the guide that has been referenced. Mods could it get added to the tech archives? Its actually not THAT easy to find with a search.
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: GTX MATT] #3073597
09/02/22 02:58 PM
09/02/22 02:58 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I can't help moparts with retaining documentation and the spoon feeding is over wrench
If you finally catfight read the guide, it will tell you all about why you need a 195 degree thermostat. I am not repeating what is already well documented. Read the guide . We [there is 2 of us] work six pak carb set ups typically weekly and we are very successful.
– if the op wants to work this offline he should pm me.
The new guide is greatly improved but I see no reason to publish it. Convince me otherwise in a PM or just send money. eek drive weld drive
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: SomeCarGuy] #3073615
09/02/22 04:01 PM
09/02/22 04:01 PM
I don't buy or use any gas additives, none :twocents
Fresh gas only up
I do buy aviation 100 Low lead gasoline at the local airport for one of my cars that sits a lot between uses because it has a 18-month shelf life up work
I do need to warn everyone about using any leaded fuel on highways, the Feds have a law that they can charge you with, if caught and convicted, violating it that has a ten-year jail sentence max shock whiney Race or aviation gas tskscope whistling realcrazy
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: ThermoQuad] #3073690
09/02/22 09:25 PM
09/02/22 09:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
down
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: TJP] #3073795
09/03/22 10:53 AM
09/03/22 10:53 AM
ThermoQuad Offline
ThermoQuad  Offline
I am having way too much fun with this violin
We get paid for fixing/tuning six paks and debunking the ignorance that surrounds the fuel system.
Most six pak cars run like turds but the owner will tell me it runs great
Again: Convince me why i should post the latest version of a well written/researched technical document, with a previous published version not as well written [that works if you can read] for free? Send money i will provide you a printed copy
I offered [free] offline help to the OP, should i charge him instead?
chargerwork
eek
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: ThermoQuad] #3074048
09/03/22 10:02 PM
09/03/22 10:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
chargerwork
eek
This board IMO is about helping each other not making money unless you advertise on it. I have been here since 1998 or so, have 5.5 times as many posts (mostly trying to help another that I don't know), and have never asked for a red cent.
And yes I run a business too twocents beer
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: TJP] #3074108
09/04/22 07:39 AM
09/04/22 07:39 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Well another potentially good six pack post run off course
Excuse Thermoquad - hes just old and grumpy with poor
internet charisma. Doesnt make him completely a bad person.
But …….
.op just wanted to know about plugs and stat
Then he posts it runs like crap ..or idles like crap.
Who knows
I was screwing with some carbs last night
1/8 turn on outboard baseplate changed my af by 1 point.
You have six screws to adjust to get it right and a Pv
which means you need to know engine vacuum and then
you have to play with timing
Its not take out of box and bolt on .
Unless you can get the basics running right at 190-195
All bets are off .
If youre going a 1/4 mile at a time then you can worry about
Low temps - AFTER you get it idling and performing at temp ..
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: sogtx] #3074135
09/04/22 10:20 AM
09/04/22 10:20 AM
ThermoQuad Offline
ThermoQuad  Offline
lol, there is sogtx giving away our secrets, not old n cranky...lol, no more patience for the bs. None. You all can't remember $hit and it's not my job to prop up the lost and lazy.
Read the old guide, someday i might publish the latest and greatest guide. In the meantime if some one would send me money for the latest version i would let the cat out of the bag. eek
catfight catfight catfight
I offered the OP free help and i get crickets....... drive
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: ThermoQuad] #3074224
09/04/22 02:31 PM
09/04/22 02:31 PM
CA
crackedback Offline
crackedback  Offline
CA
Have a gofundme started for you... up to 22 cent, some pocket lint and old receipt. smile
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: crackedback] #3074323
09/04/22 10:41 PM
09/04/22 10:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
bow I'll up it to 23 cents but he'll have to pay my transaction fee laugh2
Re: Stewart Components 195 Thermostat Part# Needed 340-6 [Re: TJP] #3074379
09/05/22 06:28 AM
09/05/22 06:28 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Did the OP fig out his🤔 issue ?
