Ram backup cams
#3073456
09/02/22 12:53 AM
09/02/22 12:53 AM
Posts: 1,963 ID/MT
Cheeto
ID/MT
2021 Ram has crisp clear image and hitch ball dotted line. 2017 Ram has crappy image and no dotted line. Is the image quality difference in the cams, the head units or both? Can a newer tailgate handle/cam be swapped into the 2017 for at least a better image?
Cheeto It's not perfect. It's not correct. It's not yours!
Re: Ram backup cams
[Re: Cheeto]
#3073535
09/02/22 11:42 AM
09/02/22 11:42 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
2021 Ram has crisp clear image and hitch ball dotted line. 2017 Ram has crappy image and no dotted line. Is the image quality difference in the cams, the head units or both? Can a newer tailgate handle/cam be swapped into the 2017 for at least a better image? It might be the head unit. My wife has a 2015 Grand Cherokee. We wanted the newer head unit so Apple Carplay would work. I bought one from a 2019 off of Ebay and installed it. The backup camera image is much crisper and the night vision is even better now.
68 Barracuda Formula S 340
Re: Ram backup cams
[Re: Cheeto]
#3073537
09/02/22 11:47 AM
09/02/22 11:47 AM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Have you checked to make sure the camera lens isn't dirty/scratched?
I believe the grid lines are programmable...check your OM.
Re: Ram backup cams
[Re: John_Kunkel]
#3073685
09/02/22 09:13 PM
09/02/22 09:13 PM
Posts: 1,963 ID/MT
Cheeto
ID/MT
I believe the grid lines are programmable...check your OM. Lens is clean and clear. Truck only has 46k on it. New to us, no OM. I thought I checked in the menu for the hitch guide lines but may not have as we were in a crunch to get on the road. I will check again. Thank you both.
Re: Ram backup cams
[Re: John_Kunkel]
#3074071
09/03/22 11:08 PM
09/03/22 11:08 PM
Posts: 1,963 ID/MT
Cheeto
ID/MT
Thank you for the link. I have the guidelines active but it does not have the center dotted line that corresponds to the hitch ball.
Re: Ram backup cams
[Re: Mastershake340]
#3074297
09/04/22 08:17 PM
09/04/22 08:17 PM
Posts: 1,963 ID/MT
Cheeto
ID/MT
...only is found in the trailer convenience package or whatever it was called, that added a bunch of extra cameras to help prevent the blind spots by the trailer and trailer backing aids etc? Possibly. I have "trailer blind spot monitoring" on the '21 but no other cameras aside from the one in the tailgate handle. Pretty sure it uses the sensors in the tail lights and adjusts distance when you have a trailer connected.
Re: Ram backup cams
[Re: Cheeto]
#3079916
09/23/22 11:37 AM
09/23/22 11:37 AM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
My 2015 2500 has the tailgate camera, nice feature but since I don't have bluetooth the monitor is in the mirror and pretty small. My 2015 3500 has no camera at all, and I still have no problem lining up a trailer hitch when backing up. I have noticed that most modern conveniences make people lazier or dumber...LOL
JB Rhinehart, Realist
A-Body's RULE!
Re: Ram backup cams
[Re: Rhinodart]
#3079918
09/23/22 11:41 AM
09/23/22 11:41 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
My 2015 2500 has the tailgate camera, nice feature but since I don't have bluetooth the monitor is in the mirror and pretty small. My 2015 3500 has no camera at all, and I still have no problem lining up a trailer hitch when backing up. I have noticed that most modern conveniences make people lazier or dumber...LOL Both actually.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
