Re: Quest for 1000 hp, slow going!
[Re: 440Jim]
#3104572
12/22/22 02:08 PM
12/22/22 02:08 PM
Posts: 16,924 NC
440Jim
NC
Those 572-13 exhaust ports look much bigger than 440-1. What size are yours ?
[Re: 440Jim]
#3104728
12/22/22 10:25 PM
12/22/22 10:25 PM
Posts: 9,990 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Those 572-13 exhaust ports look much bigger than 440-1. What size are yours ? Thanks Dwayne! I sure hope it does! Jim, my header flanges are for the 572-13 heads, and gaskets will be fit to the ports if need be.
[Re: 440Jim]
#3104815
12/23/22 09:43 AM
12/23/22 09:43 AM
gregsdart
Good to hear. I look forward to the dyno numbers. As you said, don't forget that rear cam plug... From your other thread/topic you decided to build the 550 CID not the 580, right? 4.504 bore, 550 CID 4.315 stroke crank from Crower, with center counter weights. Block is an aluminum BMP 4.5ā bore, new block. The heads are 572-13 385cc, with additional work by Larry Smith. Intake is a 3X, reworked by Wilson manifolds. Compression will be 14.6 with 550 cubes. Cam will be the 0.868 lift roller, 285/296/113 @ 50
Yes Jim i decided to go with the center weighted crank and less stroke. My main thought was the weight of the 580 rotating assembly. I hope the CW crank will produce less bore distortion and provide better ring seal as a result. The thought just crossed my mind, how many new v8 performance motors have center weighted cranks? I bet almost all.
[Re: gregsdart]
#3104885
12/23/22 01:24 PM
12/23/22 01:24 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Greg glad to see you are back at it and getting close..
As for CCW cranks look at any professional race engine in any racing series From F1 to WOO to Trophy Truck and you will find them in every engine. You main bearings and caps will thank you...
[Re: gregsdart]
#3104907
12/23/22 02:20 PM
12/23/22 02:20 PM
Posts: 16,924 NC
440Jim
NC
Jim, my header flanges are for the 572-13 heads, and gaskets will be fit to the ports if need be. I have notes on several intake port sizes, but not much on exhaust ports. Some port jobs will be a little different, too. I was going to compare your finished exhaust port dimensions (572-13 CNC 385) to what the guy put on my B1 heads. Intake port openings: 1.260 x 2.300 Indy SR (gasket 440-212) Indy website 1.340 x 2.630 Max Wedge (Felpro gasket) 1.340 x 2.650 Indy 440-1 (gasket 440-216) Indy website, for their intake manifold gaskets 3.55sqin 1.375 x 2.650 Indy 440-1 (CNC 345), 3.64sqin-0.335 corners 3.31 1.475 x 2.700 Indy 572-13 (gasket 440-218) Indy website, for their intake manifold gaskets 3.98sqin 1.600 x 2.660 B1 original (from gaskets bought from Koffel's Place) 4.25sqin 1.750 x 2.730 Jim's B1 originals CNC ported (previous owner, unknown shop) 4.78sqin-0.335 corners 4.44sqin
1.835 x 2.050 Indy Hemi (gasket 426-258) 3.76sqin
Exhaust ports: 1.550 x 1.960 Indy 440-1 (CNC 345), 3.04sqin-0.335 corners 2.70 1.xx x X.xx Indy 572-13 (CNC 385), sqin X. xx X.xx B1 original (from ) sqin 1.710 x 2.070 Jim's B1 originals CNC ported 3.54 sqin, 3.206 sqin (curved sides)
[Re: Al_Alguire]
#3104916
12/23/22 02:56 PM
12/23/22 02:56 PM
gregsdart
As for CCW cranks look at any professional race engine in any racing series From F1 to WOO to Trophy Truck and you will find them in every engine. You main bearings and caps will thank you... Thanks Al. Once i quit overthinking it, the cw crank was the only choice. Your comments carried a lot of weight. On top of it being easier on bearings and crank, i assume it is much better for an aluminum motor.
[Re: 440Jim]
#3104965
12/23/22 05:41 PM
12/23/22 05:41 PM
gregsdart
Jim, 572-13, 1.90 wide, 1.60 tall.
[Re: gregsdart]
#3105053
12/23/22 09:35 PM
12/23/22 09:35 PM
gregsdart
The rest is easy, right? Well. Not quite. The Jesel belt drive spaced out the crank trigger pickup bracket. No oroblem. Make a spacer, done. BUT the injection pump is now interfering with the extra oil line for the dual pickup system. And i have no idea why the 255 mm belt that drives it is now too tight. That port in the block right by the 2nd line i believe is for use with that line? Anyone know what fitting goes with that port? It isn't pipe thread. Uses an O ring and straight threads. I ordered a fitting to extend out farther from the pump so maybe the 2nd oil line can then fit in front of the fuel pump to tank line . Trouble is, that fitting won't get hear till January. So , i plan on capping the 2nd line if i have to to get this thing on the dyno.
[Re: gregsdart]
#3105107
12/24/22 03:08 AM
12/24/22 03:08 AM
Al_Alguire
Las Vegas
FWIW Ihave never run a dual line just singles for me. Current engines are both -16 singles except the blue car which is a single -12
[Re: gregsdart]
#3105142
12/24/22 10:02 AM
12/24/22 10:02 AM
Posts: 16,924 NC
440Jim
NC
That port in the block right by the 2nd line i believe is for use with that line? Anyone know what fitting goes with that port? It isn't pipe thread. Uses an O ring and straight threads. It is AN-12 straight thread O-ring. This is my labeled block hardware for the BMP aluminum block.
[Re: gregsdart]
#3105161
12/24/22 11:16 AM
12/24/22 11:16 AM
Posts: 2,041 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
[quote=gregsdart]The rest is easy, right? Well. Not quite. The Jesel belt drive spaced out the crank trigger pickup bracket. No problem. Make a spacer, done. BUT the injection pump is now interfering with the extra oil line for the dual pickup system. And i have no idea why the 255 mm belt that drives it is now too tight [quote]
This year while working at a race engine shop I have installed 5 Blower Shop "baby blowers" on big BBC engines, all over 600 ci. Some were iron blocks, some alum, all were after market. Each one was just a little different. The blowers and related parts (pulleys, brackets, ect.) were mostly bolt on, but when it came to vacuum pumps, fuel pumps, water pumps, crank triggers and plumbing for each, that was a different song. And, with most of them going into dragster chassis, I had to be mindful of the radiator clearance up front. Easy, bolt on. Yeah, right!
Brian
[Re: Cab_Burge]
#3105367
12/25/22 04:27 AM
12/25/22 04:27 AM
gregsdart
https://photos.app.goo.gl/4tCuwodqqSj7joLbA A little massaging on the fuelpump bracket got me what i needed for clearance for belt tension. I was able to run the second line under the oil pump body, allowing room for my injection pump. Luckily i didn't tear much hair out in frustrationš i don't want to lose any more! So now i am very close. Bolt the waterpump and hoses on, put a lifting plate on the intake manifold, install the rear cam plug. Wait for R&R to open monday to get a dyno time!
