Re: You get to pick one
[Re: Ramrod39]
#3073124
09/01/22 01:47 AM
09/01/22 01:47 AM
Posts: 27,453 So Cal
autoxcuda
So Cal
Olds... Even being a F-85 (short wheelbase, short rear door, no sunroof)
The 71 Plymouth 4 door front ends are not very sporty or appealing. If it had a RR/GTX front end on it, that would be cool.
The Plymouth/Dodge B-body wagons had a cheap look that was a little outdated. The Sedan-like rear window surrounds is something from the early-mid 60's. And that continuous rain gutter that's not needed for the rear windows. Makes it look like the top of a Tin can.
[Re: BloFish]
#3073128
09/01/22 02:17 AM
09/01/22 02:17 AM
autoxcuda
So Cal
Biggest motor you could get in B-body wagon was a 383/400.
Olds wagon had optional 455 from 70-72. And even rated at 365 hp in 1970, same as 442 std motor rating. The Colonnade 73-up wagons had 455 available to start too.
