Hemi Main Bearings
#3072400
08/29/22 02:39 PM
08/29/22 02:39 PM
Posts: 10,703 North Dakota
6PakBee
North Dakota
With all the options available for bearings, what brand/type would be the equivalent of the OEM bearing used in the second generation Hemi?
Re: Hemi Main Bearings
[Re: 6PakBee]
#3072458
08/29/22 06:33 PM
08/29/22 06:33 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I use King Bearings in my Hemi.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3072509
08/29/22 10:54 PM
08/29/22 10:54 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I use King Bearings in my Hemi. X2 , Muscle Motors put King main bearings in my G2 Hemi build back in 2017
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: rumblefish72]
#3072512
08/29/22 11:08 PM
08/29/22 11:08 PM
Posts: 268 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I use King Bearings in my Hemi. X2 , Muscle Motors put King main bearings in my G2 Hemi build back in 2017 That's gotta be one of the last engines those guys built
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3072549
08/30/22 08:45 AM
08/30/22 08:45 AM
rumblefish72
They were cleaning out the building when I picked it up in June 2017. It probably was the last Hemi build they assembled and dynoed. I was very happy when they gave me the call to come get it.
[Re: Cab_Burge]
#3072575
08/30/22 11:03 AM
08/30/22 11:03 AM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I like and now use the Federal Mogul narrow groove truck main bearings, M4500. the original wide street hemi bearings had too much oil clearances and don't have the wider surface area to support the crank like the better narrow full groove truck bearings do: scope: Cab, are you sure about that number?
2011 Drag Pak Challenger
[Re: rickseeman]
#3072591
08/30/22 12:30 PM
08/30/22 12:30 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
I'm glad you ask, I was wrong. The correct number is 4095M for the full narrow groove truck H.D. Seal Power Brand main bearings for RB blocks.
[Re: rickseeman]
#3072594
08/30/22 12:44 PM
08/30/22 12:44 PM
rickseeman
Stuttgart, Arkansas
The Clevite MS1795V is one. The Federal Mogul/Sealed Power M4095 is fully grooved. Speed Pro 119M is another. There is also King. You didn't say if you were using an old Street Hemi block or a new one. The new blocks can use large thrust if you want it. Clevite MS-1277HG is large thrust fully grooved but I haven't test fit to see if it will clear a large radius crank in case you are using one.
[Re: rickseeman]
#3072632
08/30/22 02:51 PM
08/30/22 02:51 PM
6PakBee
North Dakota
The Clevite MS1795V is one. The Federal Mogul/Sealed Power M4095 is fully grooved. Speed Pro 119M is another. There is also King. You didn't say if you were using an old Street Hemi block or a new one. The new blocks can use large thrust if you want it. Clevite MS-1277HG is large thrust fully grooved but I haven't test fit to see if it will clear a large radius crank in case you are using one. This would be a '66 casting original block. I didn't think the OEM bearing was fully grooved. Am I under a misconception?
[Re: 6PakBee]
#3072661
08/30/22 03:52 PM
08/30/22 03:52 PM
Cab_Burge
[quote=rickseeman]
This would be a '66 casting original block. I didn't think the OEM bearing was fully grooved. Am I under a misconception? All the M.W and hemi motors came with the Clevite wide full groove main bearings with .003+ oil clearances
[Re: Cab_Burge]
#3072682
08/30/22 04:35 PM
08/30/22 04:35 PM
rickseeman
Stuttgart, Arkansas
In a normal application anything would probably work fine. If you want fully grooved (that's what the Mopar Hemi book says to use) then Sealed Power/Federal Mogul full groove main bearings 4095M or the Clevite MS-2324P is full groove. The MS-2324P is a TM-77 (Tri-Metal) which is what the OEM Hemi bearings were.
[Re: 6PakBee]
#3072740
08/30/22 06:45 PM
08/30/22 06:45 PM
Posts: 3,069 Michigan
A727Tflite
With all the options available for bearings, what brand/type would be the equivalent of the OEM bearing used in the second generation Hemi? When picking your bearing make sure you look at the technical info for those bearings and compare it to your actual journal diameters. Some of the wide full groove bearings give you extra clearance. Low speed oil pressure will generally be lower than the narrow groove bearing.
[Re: rickseeman]
#3072868
08/31/22 10:35 AM
08/31/22 10:35 AM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
... Federal Mogul/Sealed Power M4095 is fully grooved. Speed Pro 119M is another... M4095 is a "narrow" 360* groove; the 119M is a "wide" 3/4 groove (although it's more like 5/8 IMO). I prefer the 119M, but that's an opinion not based on any comparative data.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
