727 front clutch spring quantity - need recommendation #3071385
08/25/22 02:42 PM
08/25/22 02:42 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
[Thanks for previous responses on the blocker rod...]
Currently building a 727 for 99% street use and automatic shift ('72 Road Runner, 451 low-deck stroker, 550hp).
Trans will have:
- TransGo TF-2 kit (automatic shift)
- Early-style front servo with A&A springs
- 4.2 or 3.8 lever
- Rigid front band relined
- Typical clutch upgrades
How many return springs should I run on the front clutch piston? This '72 400 'hi-perf' trans had 9 originally. I keep reading about going to 12, but don't know if that is for very high line pressure, manual VB, etc. Any advice appreciated. Thanks.
Re: 727 front clutch spring quantity - need recommendation [Re: WarEagle1] #3071508
08/26/22 12:14 AM
08/26/22 12:14 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
It all kinda works together, I like about .020 clearance per friction in the front clutch, 8-9 springs, and about a .150 restrictor in the front clutch passage in the case. If it flares on 2-3 shift make the restrictor bigger, or remove it. I would not use 12 springs on a med pressure street trans. Others will dasagree.
