Re: 3.55 swap to 2.76 gears?
[Re: TJP]
#3070767
08/23/22 01:26 PM
08/23/22 01:26 PM
Posts: 19,342 north of coder
moparx
Depending on your reason for doing so, be aware that the change may move the engine out of its most efficient range resulting in a loss of mileage as well as placing and additional load on the engine and transmission. Where you do the majority of your driving as well the terrain may also be a factor to consider this ^^^^^ if this were me, [you really DON'T want to be me ] i would try to borrow a much larger [taller] set of rear tires to see how this would affect your mileage. you can mathematically get close to figuring out what gear ratio the taller tires would simulate, then go from there. this would be easier, quicker, and cheaper than buying a gear set and having it installed [if you can't do it yourself]. if you find something you don't like, drive-ability wise, you could try a different height tire and test again. as above, i have seen a loss of mpg going to a shorter gear set many times, even though a well figured out equation suggests otherwise. just my opinion and experience. your "mileage" will vary.
[Re: moparx]
#3070812
08/23/22 02:59 PM
08/23/22 02:59 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Depending on your reason for doing so, be aware that the change may move the engine out of its most efficient range resulting in a loss of mileage as well as placing and additional load on the engine and transmission. Where you do the majority of your driving as well the terrain may also be a factor to consider this ^^^^^ if this were me, [you really DON'T want to be me ] i would try to borrow a much larger [taller] set of rear tires to see how this would affect your mileage. you can mathematically get close to figuring out what gear ratio the taller tires would simulate, then go from there. this would be easier, quicker, and cheaper than buying a gear set and having it installed [if you can't do it yourself]. if you find something you don't like, drive-ability wise, you could try a different height tire and test again. as above, i have seen a loss of mpg going to a shorter gear set many times, even though a well figured out equation suggests otherwise. just my opinion and experience. your "mileage" will vary. I had good results with a 275-65-20 on my full size ex cab long bed 318 magnum (same exact engine) with 3.55s. With my very short 15" tires the math comes out around 3.1 gear ratio to match the top gear RPM, 2.76 is not much of a stretch especially considering how much smaller this truck is both in weight and aero.
[Re: HotRodDave]
#3071037
08/24/22 11:19 AM
08/24/22 11:19 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
HRD my 92 dakota has 8.25 with 3.55. Don't know what axle is under yours. That 2002 RT though will have 9.25 rear though and likely 3.92 gears.
If it were me I would start out by running a taller tire to see where you like the rpms then possibly do a gear swap later. Lots easier to swap a couple used tires on than make a mistake on the gear choice.
I ran a 31/10.5/15 tire on my 92 dak 2wd fit fine in the rear, slight scrub at full lock on front. The tall tire made it great as an interstate cruiser.
[Re: mgoblue9798]
#3071088
08/24/22 02:07 PM
08/24/22 02:07 PM
HotRodDave
Kalispell Mt.
I ran a 31/10.5/15 tire on my 92 dak 2wd fit fine in the rear, slight scrub at full lock on front. The tall tire made it great as an interstate cruiser. I have run much taller tires with a much larger truck and the same engine and was fine with the results, now I want to gear to get the same or very slightly more RPM reduction than the taller tires gave. A taller tire is less effective than a gear swap as it puts the truck higher up in the wind and most any tires are gonna be wider as they get taller witch will also reduce the effect I am after. I have thought this thru and experimented and am convinced it is the right thing for me to do, my only question now is how to do it not "if" I should do it. As for the R/T diff... yes it is a 3.92, they all were, I am just planning to use the limited slip carrier if it will fit and not the gears themselves.
[Re: NANKET]
#3071122
08/24/22 04:14 PM
08/24/22 04:14 PM
HotRodDave
Kalispell Mt.
What is the rear tire height? Hoe about 3.2 or 2.9 gears. 2.76 is to too far the other way. Does it have and OD trans?
I’ve never liked 2.76 axle in anything, kills the torque. Even with 25” tall rear tires.
Jump on a 10 speed bike and take off on 8th gear, that’s what a 2.76 does, takes it out of the power band. Again, I am not concerned about the ratio and TQ. I had a 2.76 gear in my 318 cuda with a smiilar tire height, it still had more power than the tires could handle and this 318 has more TQ.
[Re: mopars4ever]
#3071172
08/24/22 08:00 PM
08/24/22 08:00 PM
HotRodDave
Kalispell Mt.
97 and newer used a 29 spline axle. 27 on the older 70`s 80`s and up to 96. I suppose that means I can't use this limited slip carrier I already have. I guess I will be looking fur one of those also. That is why I asked, thanks!
[Re: moparx]
#3071635
08/26/22 02:36 PM
08/26/22 02:36 PM
Posts: 287 NW Illinois
MoonshineMattK
NW Illinois
Depending on your reason for doing so, be aware that the change may move the engine out of its most efficient range resulting in a loss of mileage as well as placing and additional load on the engine and transmission. Where you do the majority of your driving as well the terrain may also be a factor to consider this ^^^^^ if this were me, [you really DON'T want to be me ] i would try to borrow a much larger [taller] set of rear tires to see how this would affect your mileage. you can mathematically get close to figuring out what gear ratio the taller tires would simulate, then go from there. this would be easier, quicker, and cheaper than buying a gear set and having it installed [if you can't do it yourself]. if you find something you don't like, drive-ability wise, you could try a different height tire and test again. as above, i have seen a loss of mpg going to a shorter gear set many times, even though a well figured out equation suggests otherwise. just my opinion and experience. your "mileage" will vary. Was worried about this when I bought the 5spd for my charger. Was 3.23w/OD, Now I have a 2.76 and overdrive Oversize tire is a great idea to try
