Determining brake fluid type #3070532
08/22/22 05:12 PM
08/22/22 05:12 PM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
Any fool proof ways to determine if brake fluid is dot 3 or 4
Versus dot 5 silicone ?
Re: Determining brake fluid type [Re: gtx6970] #3070539
08/22/22 05:23 PM
08/22/22 05:23 PM
robertop Offline
robertop  Offline
Good question! Not to be asmartxxx, they probably taste differently
Re: Determining brake fluid type [Re: robertop] #3070545
08/22/22 05:40 PM
08/22/22 05:40 PM
It's a dry heat
It's a dry heat
Its a car I did for a client about 5 or 6 years ago.
And I cant remember if I used dot 5 or not.
I am now 2000 miles away from said client and I simply dont remember what i put in it .
And his car is low on fluid and doesnt want to mix fluid types if possible
Re: Determining brake fluid type [Re: gtx6970] #3070548
08/22/22 05:43 PM
08/22/22 05:43 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Pretty sure Dot 5 is purple in color.
Re: Determining brake fluid type [Re: mopars4ever] #3070749
08/23/22 12:43 PM
08/23/22 12:43 PM
moparx Offline
moparx  Offline
dot 5 is purple.
dot 3 & 4 are light amber[ish] in color.
i wouldn't put 5 in if you suspect it truly isn't purple color.
as to 3 & 4, i would just add some 4.
if a true color can NOT be determined, to be on the safe side, i would drain, flush with alcohol, then fill with your choice of fluid.
also, don't confuse dot 5 with dot 5.1. 5 is silicon [?] based, while 5.1 is not. also, i do not know what color 5.1 is, although i suspect it may be close to the color of 3 & 4.
beer
Re: Determining brake fluid type [Re: gtx6970] #3070769
08/23/22 01:34 PM
08/23/22 01:34 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
The purple can fade over time. Not sure about 5 years, but I did flush once after about 15 years and it was not purple any longer.
I say put some fresh DOT 3 in a clear glass and put a sample of this fluid in it. If it mixes, should be same DOT rating. If it is DOT5, it will separate.
Re: Determining brake fluid type [Re: gtx6970] #3070795
08/23/22 02:17 PM
08/23/22 02:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Put a few drops on a freshly painted surface, if the paint curdles, it isn't DOT 5 silicone.
Re: Determining brake fluid type [Re: John_Kunkel] #3070827
08/23/22 03:48 PM
08/23/22 03:48 PM
It's a dry heat
It's a dry heat
Thanks all
He said fluid in it was a clearish color. And was wondering if the color faded over time. But im pretty sure dot 3 does not
Owner went back thru invoices and found dot5 billed...which i was pretty sure what i put in it.
He is going to flush and refill it anyway...simply from age. But going back with dot5
Gonna have to remember the mixing method test for future reference
Re: Determining brake fluid type [Re: gtx6970] #3071079
08/24/22 01:24 PM
08/24/22 01:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Standard fluid will mix with water. Silicone will not.
Doug
