Page 6 of 6 1 2 3 4 5 6
Re: RR project 700 hp street/strip [Re: AndyF] #2910421
04/15/21 10:14 AM
04/15/21 10:14 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Beautiful car!
Re: RR project 700 hp street/strip [Re: AndyF] #2910424
04/15/21 10:21 AM
04/15/21 10:21 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by AndyF
Here is a shot of the other side of the car. The paint is so shiny that it is a little tough getting a good picture. I need to shoot it on some artificial grass or something that doesn't reflect so much.
I chuckle when people say body work needs to be perfect if it's Black. No it needs to be perfect for any color, and this shows what perfect body work looks like. You can tell that car is arrow straight, and someone spent a lot of time on it.
69 GTX 68 Road Runner
Re: RR project 700 hp street/strip [Re: JERICOGTX] #2910427
04/15/21 10:25 AM
04/15/21 10:25 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by JERICOGTX
no doubt Rich has added a ton of skills doing it himself. Doing a fine job at that.
Means alot coming from a guy with Mad Skillz such as yourself. Thank you.
Rich H.
Esse Quam Videri
Re: RR project 700 hp street/strip [Re: AndyF] #2910431
04/15/21 10:29 AM
04/15/21 10:29 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Super Nice. The bodywork and paint just leaps off the screen.
Rich H.
Esse Quam Videri
Re: RR project 700 hp street/strip [Re: ZIPPY] #2910473
04/15/21 12:29 PM
04/15/21 12:29 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
One sleek machine right there. Kudos to the paint/body guys! bow
Re: RR project 700 hp street/strip [Re: bobby66] #2910477
04/15/21 12:46 PM
04/15/21 12:46 PM
AndyF Online content OP
AndyF  Online Content OP
This is what it looked like before it went to the body shop.
Re: RR project 700 hp street/strip [Re: AndyF] #2910566
04/15/21 04:59 PM
04/15/21 04:59 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Wondering whats the story be hide this?
Re: RR project 700 hp street/strip [Re: racerx] #2910575
04/15/21 05:16 PM
04/15/21 05:16 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Andy can you show how you ran the accusump to the trunk ?
Re: RR project 700 hp street/strip [Re: 10secGTX] #2910600
04/15/21 06:11 PM
04/15/21 06:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
I'd like to see that too! Must be an extra two quarts in the lines !!
Re: RR project 700 hp street/strip [Re: 10secGTX] #2910643
04/15/21 07:49 PM
04/15/21 07:49 PM
Hard to get pictures without having the car on the lift but basically used AN hose wrapped in fiberglass sleeve material and ran it along the frame. Used bulkhead fittings where we had to go thru the frame. Took a few hours of nasty work with various hole saws, uni-bits and nutserts to complete the task.
Re: RR project 700 hp street/strip [Re: bobby66] #2910921
04/16/21 12:34 PM
04/16/21 12:34 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
iagree Very nice work .
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: RR project 700 hp street/strip [Re: mopar dave] #2911804
04/18/21 10:57 PM
04/18/21 10:57 PM
Louisiana
BiomedTechGuy Offline
Louisiana
Originally Posted by mopar dave
Andy, it that a progression Ignition distributor? If so, do you like it? I like the fact the timing curve can be adjusted from your Iphone. Thinking about trying one.
I corrected your spelling in the quote.
Ok, first thing is Andy F knows me from another forum as well as this one, and I have THE UTMOST respect for him and I've been blessed with his advice. Having said that, I am devouring this thread as Andy knows I have been posting about my 70 V-code Roadrunner and doing a powerful stroker motor for it.
I'm writing that because it's REALLY HARD to stop reading, BUT I am a HUGE FAN of the PROGRESSION IGNITION and I can't wait to get one, so I had to stop and say GET ONE!! I've DREAMED of having an ignition system that allows the kind of control the Progression Ignition does! Watch the videos on their website. I downloaded the free app to my phone to control the distributor even though I don't have it yet, so I could "play with" the programming by choosing the "work offline" option in the app. You have to turn Bluetooth on your device, even though you are just "playing". I entered the basic information the app asks for, and it generated a timing map based on those initial values. ONE example of how I can use the flexibility of timing programmability is my 440 6bbl idles around 900-950 RPMs because I have a choppy cam. I recently added air conditioning, but I've had to increase my idle to keep it from dropping too low when the AC is turned on. Similar to putting an automatic transmission in gear. I could rig a solenoid to increase the idle speed, but with the Progression Ignition I can advance the timing just in the narrow RPM range that it slows to, say 800-900 RPMs, and that will bump the RPMs back to "normal idle" speed! Certainly my main reason for wanting it is the absolute control over the timing curve, but the example I just gave, the "ignition disable" security feature, are just a couple of the bonus benefits of the Progression Ignition!!
I use my car mostly for cruising to local and "near state" car shows/events (2-5 hours each way drive, like less than 2 hrs to The Battleship Alabama or about 5 hrs to The Wellborn Museum) and the MAIN EVENT for me each year is a solid week of cruising up and down the Mississippi Gulf Coast for Cruisin The Coast, stop and go traffic, burnouts, 1st and 2nd gear "street sprints" and what has been a lot LESS "Test and Tune" 1/4 mile events at Gulfport Dragway. The main reason why I haven't been running my car at the track was no off the line traction, and a big reason for that was worn out factory leaf springs. Bad brakes and a wish list longer than my arm to address the launch, replacing the brakes with a 4 wheel 6 piston Wilwood disc brakes setup, PREPARING my Roadrunner for the POWER of the 541 stroker motor: USCT subframe connectors, front and rear torque boxes, Strange Engineering chromoly steel everything from the slip yoke to the pinion yoke, Calvert split mono leaf springs and sliders, Andy's AR Engineering plates front and rear to strengthen the front leaf spring mounts, Viking XS Warrior triple adjustable rear shocks, McLeod RXT dual disc clutch and pressure plate, hydraulic throwout bearing conversion and the HitMaster launch control for my Passon Performance 5 speed. Complete new front suspension and K-member from QA1.
I'm listing all that because it took care of problems I was having, improves the performance I have now, and lays a STRONG, RELIABLE foundation for the FIVE HUNDRED FOURTY-ONE cu in Bill Mitchell aluminum RB block I've bought.
IT MUST HAVE A 6 BBL!! I've taken a lot of grief over wanting a "street/strip" car with a manual transmission and that much power, but here's a thread MY HERO and MENTOR ANDY F has started with almost EXACTLY WHAT I'VE DREAMED OF AND HAVE FINALLY MADE STRIDES TOWARDS HAVING: a manual transmission equipped 700 horsepower "street/strip" Roadrunner!
That's it, I hope you get the Progression Ignition! I'm getting one asap. I'm concerned about clearance of the distributor with the TF 270 head and my fabricated aluminum valve cover, so I'd love to see any posts from anyone with TF heads and the Progression Ignition.
Re: RR project 700 hp street/strip [Re: ZIPPY] #3069697
08/19/22 08:28 PM
08/19/22 08:28 PM
Here is the car today. I stopped by his place to look over the tune in the Sniper since he has been putting some miles on the car. While I was there I walked around it with my cell phone and shot a quick video.
https://www.youtube.com/watch?v=fGiFuOuBnvQ
Re: RR project 700 hp street/strip [Re: AndyF] #3069752
08/20/22 12:00 AM
08/20/22 12:00 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Car is so similar to our ‘68 road runner it too is running a 505 pump gas but with Indy heads I had fast68plymouth (Dwayne) work back in 2008, 4.10 Dana, 9x30 Hoosier drag radials. Looking forward to see what this car runs. I am running a brake in the 727 so dumbed down power (MSD Grid) at the hit it has been 10.18 at 131 but turned it down a bit and keeps a consistent 10.30-10.40 range at 128-130. Car has been shelved for many years and bringing it back up to speed once again.
1C7EDEBE-DA3B-4C10-ACE2-054326766C37.jpeg7E8232EF-8691-4DCD-BD33-65B673CEE24A.jpeg6CFFD78C-FB41-41BA-8CB6-B95C5D5229C5.jpeg
Re: RR project 700 hp street/strip [Re: AndyF] #3069790
08/20/22 08:51 AM
08/20/22 08:51 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That's Nice up
Re: RR project 700 hp street/strip [Re: racerx] #3069821
08/20/22 10:59 AM
08/20/22 10:59 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I so need to get mine done. 69 GTX clone with a TF270 headed 505. 713 HP 709 torque. Street and strip. It’s all there awaiting assembly ….
Re: RR project 700 hp street/strip [Re: markz528] #3070091
08/21/22 08:49 AM
08/21/22 08:49 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Looks super clean Andy, nice progress indeed !
