5.7 in a truck #3069868
08/20/22 12:51 PM
08/20/22 12:51 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I have two 5.7s (2 to make one good one) and a nag from an 07 charger. Would this combo go into an 2x2 88 pickup without major hassles. Original engine-trans are very tired (250 thousand)
Got the wiring harness but no controller
One more thing, is the electric pump used now strong enough for the Hemi injectors?
Re: 5.7 in a truck [Re: cudaman1969] #3070025
08/20/22 09:38 PM
08/20/22 09:38 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Holley has swap parts for that truck
Re: 5.7 in a truck [Re: Dart 500] #3070035
08/20/22 10:40 PM
08/20/22 10:40 PM
IL
furious70 Offline
furious70  Offline
IL
no the TBI pump wouldn't be up to the task, but that's an easy fix.
Holley has a lot of parts for swaps but I don't think they have nag1 into truck, probably not too hard to use their stuff to make it work. You then need the Sound German Automotive $1000 controller kit plus the shifter from the car.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 5.7 in a truck [Re: furious70] #3070050
08/21/22 12:07 AM
08/21/22 12:07 AM
fredericksburg,va
fredericksburg,va
What I’ve been reading since posting, thanks. A lot to gather over the winter.
