Power booster checking #3069457
08/19/22 09:57 AM
08/19/22 09:57 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Is there a way to check a booster on the bench? I have two off and I don’t want to install on truck and find it’s bad
Re: Power booster checking [Re: cudaman1969] #3069472
08/19/22 10:15 AM
08/19/22 10:15 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Run a hose from the check valve to a vacuum source on a running engine. Depress the pushrod that links to the brake pedal. It should go in easily and return fully as well. You'll hear if there is a vacuum leak, and it most likely will not work either.
Re: Power booster checking [Re: 469runner] #3069517
08/19/22 11:45 AM
08/19/22 11:45 AM
fredericksburg,va
fredericksburg,va
So no way of checking without hooking up to another engine?
Re: Power booster checking [Re: cudaman1969] #3069519
08/19/22 11:46 AM
08/19/22 11:46 AM
Andrewh Online content
Andrewh  Online Content
sure a vacuum pump if you have one.
you have to apply vacuum to it to test.
Re: Power booster checking [Re: Andrewh] #3069524
08/19/22 11:55 AM
08/19/22 11:55 AM
fredericksburg,va
fredericksburg,va
IF I could get a long hose up to DC.. plenty of vacuum up there.
Re: Power booster checking [Re: cudaman1969] #3069715
08/19/22 09:23 PM
08/19/22 09:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
i have pulled a vacuum on more than one booster with a hand held vacuum pump. really doesn't take that long wink
Re: Power booster checking [Re: TJP] #3069728
08/19/22 10:03 PM
08/19/22 10:03 PM
fredericksburg,va
fredericksburg,va
I have a mighty vac, I’ll give it a try
Re: Power booster checking [Re: cudaman1969] #3069731
08/19/22 10:13 PM
08/19/22 10:13 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
You'll have arms like Popeye when you are able to pull that much vacuum with one of those.
Re: Power booster checking [Re: cudaman1969] #3069827
08/20/22 11:20 AM
08/20/22 11:20 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
let us know if it works. it did for me providing the booster doesn't have a large leak. Obviously with a smaller leak it will create a vacuum but not hold it. Do verify your hose connections / adapters are not the source of the leak. I normally pull the check valve from the booster, block it, pull a vacuum and verify that it holds. reinstall and pump away. Depending on the size of the booster and the pump will dictate how many pumps /long it will take beer
Re: Power booster checking [Re: TJP] #3069862
08/20/22 12:35 PM
08/20/22 12:35 PM
fredericksburg,va
fredericksburg,va
I checked one today, when I put a tapered adapter hose for the MV I found the grommet was cracked in many places. Now I need to find a bigger adapter to fit the metal hole. Should go by HF and get their vac pump.
Re: Power booster checking [Re: cudaman1969] #3069879
08/20/22 01:39 PM
08/20/22 01:39 PM
moparx Offline
moparx  Offline
i have a vacuum pump that i use for ac systems. it works good for a lot of applications, including testing brake boosters.
i have a ball valve on the hose, so when vacuum is applied according to the gauge, i close it.
if it holds, it's good. if not, it's repair time.
i also have a mity-vac and another hand operated vacuum pump. those DO make you get Popeye arms pumping a booster, even the small ones.
beer
