451 with Trick Flow heads #3069388
08/18/22 10:17 PM
08/18/22 10:17 PM
AndyF Offline OP
AndyF  Offline OP
I helped run a 451 on the dyno today. This is a street engine with Trick Flow 240 heads, Performer RPM intake, MSD ready to run distributor and a 230/230 hyd roller camshaft. We ran it with 1 7/8 step headers. Engine made 520 hp and 550 torque. Not a race engine but it still has enough power to push a car down the track just fine. It is mellow enough to daily drive but it makes more power than any muscle car ever had so it won't be a slouch on the street. Video of the console during the testing: https://youtu.be/1ORVnCnCizI
Re: 451 with Trick Flow heads [Re: AndyF] #3069391
08/18/22 10:29 PM
08/18/22 10:29 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
That's great power from a combo & camshaft that tame. Perfect hot street engine.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 451 with Trick Flow heads [Re: AndyF] #3069414
08/19/22 01:54 AM
08/19/22 01:54 AM
Cab_Burge Online work
Cab_Burge  Online Work
looks like it was a little rich on the 2nd pull work
is this a pump gas motor on pump gas?
if so there may be another5 to 20 HP in it with some more tuning scope
