Re: Wiper motor paint
[Re: MoreParts]
#3069179
08/18/22 11:10 AM
08/18/22 11:10 AM
Posts: 18,137 Mass
DAYCLONA
Mass
You might check with Eastwood. They carried a paint kit for these at one point. Used it, kinda sucked....better off using the Dupli-color "metalcast" yellow/gold tint over Dupli-color Sea Foam Green over a cheap chrome base spray paint, experiment until you get a spray pattern/technique you like, I find that if you paint it like you hate it, you get better results rather than being anal about the applications of paint.... MikeG
[Re: 6PAX]
#3069194
08/18/22 11:51 AM
08/18/22 11:51 AM
Posts: 1,246 Slidell, LA
Ronnman
Slidell, LA
6PAX - I am not sure what the 70 wiper motor colors are, but I painted my 71 Roadrunner wiper housing/motor (see pics below). I used Eastwood “Detail Gray” for the cast hosing and Duplicolor “Sunburst Gold Metallic” number DSFM351 for the motor housing, with the end cap and screw painted either silver or Detail Gray. I also painted the wire sealing with a paint brush using a reddish primer (I do not have the can to reference).
I just wanted something decent looking as the previous owner had sprayed the unit black. Ron
[Re: 6PAX]
#3069330
08/18/22 05:50 PM
08/18/22 05:50 PM
Posts: 1,078 Georgia
Matt M
Georgia
