Re: Looking for Size of bolts for Hemi direct drive starter
[Re: dragon slayer]
#3068646
08/16/22 09:15 PM
08/16/22 09:15 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
I need to know this too. Ended up finding two starters after 3 years looking. Wu we
[Re: John_Kunkel]
#3069165
08/18/22 11:41 AM
08/18/22 11:41 AM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Your link says that the top is the stud and the bottom is the bolt. Also in 66-69 on direct drive starters there are two bolts and no stud.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: dragon slayer]
#3069564
08/19/22 01:49 PM
08/19/22 01:49 PM
MOPARMIKE69
Nashville, TN
Yes specifically looking for the 4 speed direct drive starter bolts. Mega Parts has a set.
[Re: MOPARMIKE69]
#3069568
08/19/22 02:01 PM
08/19/22 02:01 PM
cudaman1969
fredericksburg,va
Your link says that the top is the stud and the bottom is the bolt. Also in 66-69 on direct drive starters there are two bolts and no stud. Why not a stud for the top hole
[Re: MOPARMIKE69]
#3069579
08/19/22 02:49 PM
08/19/22 02:49 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Your link says that the top is the stud and the bottom is the bolt. They're wrong. Also in 66-69 on direct drive starters there are two bolts and no stud. You're right, my bad.
[Re: dragon slayer]
#3071563
08/26/22 10:16 AM
08/26/22 10:16 AM
Posts: 1,383 Az
69hemibeep
Az
This might help. My back is to sore to crawl under my car right now
1969 Hemi Roadrunner 2nd owner
[Re: dragon slayer]
#3071655
08/26/22 03:59 PM
08/26/22 03:59 PM
Posts: 1,383 Az
69hemibeep
Az
If I get a chance this weekend I'll see what is under there. Might be correct most everything else was.
[Re: 69hemibeep]
#3071681
08/26/22 06:41 PM
08/26/22 06:41 PM
Posts: 1,321 VA
dragon slayer
VA
[Re: A12]
#3071838
08/27/22 02:13 PM
08/27/22 02:13 PM
Posts: 1,383 Az
69hemibeep
Az
Well my starter was dead when I got he car and I reused the same bolts in the restoration, were they mixed up by the original owner over the years??? Anyway the top is Sems thru the starter the bottom is also Sems into the starter.
[Re: A12]
#3071840
08/27/22 02:28 PM
08/27/22 02:28 PM
Posts: 1,321 VA
dragon slayer
VA
Are you looking for the lengths of the bolts besides the diameter? Yes. Overall length, shoulder length on the one and head markings.
[Re: dragon slayer]
#3071878
08/27/22 04:56 PM
08/27/22 04:56 PM
Posts: 21,497 N.E. OHIO, USA
A12
N.E. OHIO, USA
Are you looking for the lengths of the bolts besides the diameter? Yes. Overall length, shoulder length on the one and head markings. Just as an engineering rule of thumb you just need to add the bolt diameter (i.e., in this case 7/16") to the starter flange thickness (where the bolt hole is). In other words if the starter flange is 1/2" thick plus a 1/8" washer you need to add all of those together to have the minimum correct bolt length 7/16 + 8/16 + 2/16 = 17/16 or 1-1/16" minimum That's just an example and not exact for your bolts. Standard practice is to have at the least the diameter of the bolt as thread engagement or you need to have 7/16th of the thread into the block or you will strip or pull out the threads of either the bolt or the engine block. If you get bolts that have less than the diameter of the bolt thread engagement, then they are wrong. A little more than the bolt diameter is good but not less. Good luck. Mike
