SW Temp Gauge Probe Install #3067799
08/14/22 10:52 AM
08/14/22 10:52 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I am looking at installing a Stewart Warner temp gauge on one of my cars. Here is a picture of the probe attached to the gauge. The fitting has an O.D. of approx 3/4". Where is it designed to go on a small block? Is there a port already on the motor or do I need a reducer, or...Thanks for any help
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3067840
08/14/22 01:06 PM
08/14/22 01:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Front of the intake is where I put mine.
Reducer probably needed; I think I found one that seated flush at Home Depot.
Re: SW Temp Gauge Probe Install [Re: topside] #3067923
08/14/22 05:15 PM
08/14/22 05:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
reducer needed as said.We got them at Advanced .Think they were a few bucks.
Chrysler Firepower
Re: SW Temp Gauge Probe Install [Re: therocks] #3067952
08/14/22 06:07 PM
08/14/22 06:07 PM
Can someone post a picture of the port used? Thanks
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3068011
08/14/22 10:03 PM
08/14/22 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If it's a small block Chrysler with a stock manifold the problem he is facing is the opening is for 1/8 NPT which is MUCH smaller than his probe.
More info on your setup will help as there may be a few options beer
Re: SW Temp Gauge Probe Install [Re: TJP] #3068055
08/15/22 06:59 AM
08/15/22 06:59 AM
Yes,this is exactly the problem I have.1971 340 stock intake.So I am guessing,without using a bunch of adaptors or T's,I will not be able to use this on a stock intake.
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3068114
08/15/22 10:47 AM
08/15/22 10:47 AM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
One simple brass fitting will do it on your oem intake, If I cant find the fitting today I will post a pic of it when in use.
I used this fitting on a 70 6bbl intake so I dont see why it would not work on a 4BBL.
Still lets the tip of the sender be in the coolant flow and it seemed to be accurate.
I will see If I have a extra one if you cant source one.
STOP POTATO HATE!
Re: SW Temp Gauge Probe Install [Re: Mr PotatoHead] #3068347
08/15/22 11:34 PM
08/15/22 11:34 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I’ve had to build an adapter before but it’s been decades ago so I can’t point you to the port. Just a task you need a box of fittings in front of you while under hood.
I want my fair share
Re: SW Temp Gauge Probe Install [Re: Mr PotatoHead] #3068372
08/16/22 06:55 AM
08/16/22 06:55 AM
So I need to remove the larger,outside adaptor that is on the sender probe now and find an adaptor to fit the OE sender hole and the smaller fitting on the gauge/probe correct? Thanks Mr Potato
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3068376
08/16/22 07:38 AM
08/16/22 07:38 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Whatever you use, be sure the fitting the temperature probe fits into has a seat for the probe to seal to. If it doesn't have that seat, you're gonna have leak city going on.
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3068717
08/17/22 02:56 AM
08/17/22 02:56 AM
Do NOT use any thread sealer on either part tsk, the senders need to be well ground to work properly
Re: SW Temp Gauge Probe Install [Re: Cab_Burge] #3068762
08/17/22 08:59 AM
08/17/22 08:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cab its mechanical not electric Dosent need a ground.
Chrysler Firepower
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3068777
08/17/22 09:51 AM
08/17/22 09:51 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What is the OD of the probe? I believe the Chrysler sending unit ports are 1/8 NPT.
1/8 NPT outside thread diameter is ~.375>
Your probe looks to be fairly large which my not leave enough wall thickness for an 1/8 NPT adapter beer popcorn
Re: SW Temp Gauge Probe Install [Re: TJP] #3068780
08/17/22 09:57 AM
08/17/22 09:57 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
From SW gauge install instructions
Quote
MECHANICAL TEMP GAUGE INSTALL (Figure 4):
1. Route capillary tube and temperature probe through the vehicle
firewall.
2. Using proper thread adapter for temperature port, thread
temperature probe into temperature port. Temperature probe
comes with 1/2” NPTF fitting. Contact Stewart Warner
distributor for additional adapter options.
3. Coil up and secure excess capillary tubing.
4. Make sure tubing does not come into contact with sharp edges,
moving parts or hot engine components.
Note: Capillary tubing cannot be cut. Doing so will permanently
damage the gauge and void warranty.
beer
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3069787
08/20/22 08:31 AM
08/20/22 08:31 AM
E
earlymopar Offline
earlymopar  Offline
E
What did you end up with as an adapter?
Re: SW Temp Gauge Probe Install [Re: earlymopar] #3069814
08/20/22 09:51 AM
08/20/22 09:51 AM
OK,I think you are correct with the stock intake having a 1/8" NPT thread sending unit hole.Also correct with the probe having a 1/2" NPT adaptor.I have attached a couple of photos showing I would need approx 1 1/2" deep adaptor(s) to have enough depth for the proble.I would also need an adaptor or adaptors to reduce down the 1/2" NPT on the probe down to the 1/8" NPT hole in the intake.
Re: SW Temp Gauge Probe Install [Re: TJP] #3069828
08/20/22 11:24 AM
08/20/22 11:24 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: SW Temp Gauge Probe Install [Re: TJP] #3069831
08/20/22 11:39 AM
08/20/22 11:39 AM
I see what you mean.Yes,it's approx 1/4" diameter so it would not go down into 1/8" sender hole.I would assume if I had adaptors,etc to make it fit above the intake hole there would not be enough coolant flow to get an accurate reading on top of not being real stable.
Re: SW Temp Gauge Probe Install [Re: 44D6PAKCUDA] #3069850
08/20/22 12:03 PM
08/20/22 12:03 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Ok, two fittings.... dam the memory sucks at times.
But id not be worried about how much get exposed to coolant, if the tip does it will heat soak as thats all it does in the first place. Had this config going for over 10 years with consistent readings.
I just recalled where my fitting box is so I will go dig out the spare for pics.
STOP POTATO HATE!
Re: SW Temp Gauge Probe Install [Re: Mr PotatoHead] #3069855
08/20/22 12:18 PM
08/20/22 12:18 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Here is where I ran it on a oem 6bbl intake.
STOP POTATO HATE!
