Steering box: lares vs. Blue top vs. Edelmann #3067962
08/14/22 06:49 PM
08/14/22 06:49 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
The power steering box in my 93 D350 is getting sloppy. I can get a rebuilt from Lares or Bluetop. Or a new box from Lares or Edelmann.
The Bluetop webside says their rebuilt uses oversize balls to take up the slack of the worn worm. Lares doesn't specify. The new Edelman is probably from china, but has a 100 year, 1 million mile guaranty from a very well established company. Not sure on the new Lares, but lifetime guarantee.
Does anyone have any experience that would help my make a good choice?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Steering box: lares vs. Blue top vs. Edelmann [Re: Hemi_Joel] #3067967
08/14/22 07:06 PM
08/14/22 07:06 PM
Guitar Jones Offline
Oversize balls eh? Since the worm gear doesn't typically wear evenly all the way around that sounds rather suspect to me. I got nothing else except have you tried adjusting it?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Steering box: lares vs. Blue top vs. Edelmann [Re: Guitar Jones] #3068002
08/14/22 09:21 PM
08/14/22 09:21 PM
Minnesota
Minnesota
it leaks too, it's 30 years old with lots of miles. I'm thinking adjusting will be a waste of time. I just replaced all the balljoints, control arm bushings, tie rod ends, and idler arm. It'd be nice to have everything fresh.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Steering box: lares vs. Blue top vs. Edelmann [Re: Hemi_Joel] #3068357
08/16/22 12:33 AM
08/16/22 12:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Steering box: lares vs. Blue top vs. Edelmann [Re: J_BODY] #3068417
08/16/22 10:30 AM
08/16/22 10:30 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
redheads quality has gone way down. lots of complaints.
Re: Steering box: lares vs. Blue top vs. Edelmann [Re: chrisf] #3068586
08/16/22 06:12 PM
08/16/22 06:12 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Problem with remans is they still use the steering gears from a used box so even if all the other parts are new you still will have slop in it. Get new!!! Red head web site had a pic of about 20 steer gears where a guy was cleaning them up but that pic disappeared fast because it shows they reused old parts.
