Transporting an Engine
#3067848
08/14/22 01:41 PM
08/14/22 01:41 PM
Posts: 16,117 Mesa, Arizona
dart4forte
Mesa, Arizona
Picking up my 241 Hemi next month in Washington and bringing it back to Arizona. I’d like to secure it to an engine cradle. I’m no carpenter. Anyone have any ideas on building one. It’s probably simple, I’m just overthinking this. Any help would be appreciated.
Abe Lincoln
Re: Transporting an Engine
[Re: Neil]
#3067862
08/14/22 02:32 PM
08/14/22 02:32 PM
Posts: 20,644 So Near, Yet So Far
topside
So Near, Yet So Far
A big tire - say, 31 x 10.5 pickup size - and a few tie-downs will work OK. What I did for my BBs was to take some 2x8 and 2x4, about 24" of each, and screw them together using Simpson ties, all from Home Depot. Those ties are @ inside & outside corners. The width & length match the oil pan rail, the 2x8 along the sides, and the 2x4s ft & back across the bottom so there's clearance for the harmonic balancer & rear of block. Lumber oriented vertically, of course It basically fits around the pan, with no worry about proper support, rocking, or falling over. Absolutely bulletproof, will outlive me, and easy to add a furniture dolly or dedicated wheels later if needed.
[Re: Neil]
#3067864
08/14/22 02:34 PM
08/14/22 02:34 PM
Posts: 9,299 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Yep, dont over think it.
I just take a pallet, ratchet strap a 14 inch tire off the rim to the pallet, set the motor in the hole of the tire and if it leans to the right, its happy there I use the other ratchet strap from the pallet to motor. If on a open trailer I put about 4 HD trash bags on the motor wrapped in duct tape.
Ive even shipped some costly long blocks this way... zero issues. Its shipping from a to b in a safe way not a beauty contest. Although when shipping a few out of the country they required a crate.
STOP POTATO HATE!
[Re: TJP]
#3068467
08/16/22 12:35 PM
08/16/22 12:35 PM
Posts: 15,713 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
In the back of a pickup truck I assume? I've done it in a tire also. As written especially good if it has oil pan. Allows for a little buffer for vibration and rocking but not so much it'll fall sideways. I've had ones delivered from companies on pallets and straps.
Facts are stubborn things.
[Re: dart4forte]
#3068475
08/16/22 12:55 PM
08/16/22 12:55 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I use wood 2x6 and or 2x8 nail together to fit the oil pan and notch them to clear the crankshaft on both ends to haul engines all the time BB don't need notching. I do make the ends wider than the center pieces also for stability: wrench: I put 3 to 6 inch coaster wheels (depending on which ones I have on the shelfs) on some and not on all of them. Steel wheels works better than rubber or hard plastic wheels on most surfaces
[Re: Cab_Burge]
#3068812
08/17/22 10:36 AM
08/17/22 10:36 AM
dart4forte
Mesa, Arizona
I use wood 2x6 and or 2x8 nail together to fit the oil pan and notch them to clear the crankshaft on both ends to haul engines all the time BB don't need notching. I do make the ends wider than the center pieces also for stability: wrench: I put 3 to 6 inch coaster wheels (depending on which ones I have on the shelfs) on some and not on all of them. Steel wheels works better than rubber or hard plastic wheels on most surfaces That’s kinda the direction I’m going. Last time I did a long haul transporting an engine using a tire everything kept shifting. Driving 1500 miles on [censored] roads I want to have the load firmly in place.
Abe Lincoln
[Re: dart4forte]
#3068825
08/17/22 11:04 AM
08/17/22 11:04 AM
Posts: 15,194 Omaha Ne
TJP
Omaha Ne
I use wood 2x6 and or 2x8 nail together to fit the oil pan and notch them to clear the crankshaft on both ends to haul engines all the time BB don't need notching. I do make the ends wider than the center pieces also for stability: wrench: I put 3 to 6 inch coaster wheels (depending on which ones I have on the shelfs) on some and not on all of them. Steel wheels works better than rubber or hard plastic wheels on most surfaces That’s kinda the direction I’m going. Last time I did a long haul transporting an engine using a tire everything kept shifting. Driving 1500 miles on [censored] roads I want to have the load firmly in place. I tie to all 4 corners of the bed and have never had a problem
[Re: TJP]
#3068924
08/17/22 04:19 PM
08/17/22 04:19 PM
Cab_Burge
I use wood 2x6 and or 2x8 nail together to fit the oil pan and notch them to clear the crankshaft on both ends to haul engines all the time BB don't need notching. I do make the ends wider than the center pieces also for stability: wrench: I put 3 to 6 inch coaster wheels (depending on which ones I have on the shelfs) on some and not on all of them. Steel wheels works better than rubber or hard plastic wheels on most surfaces That’s kinda the direction I’m going. Last time I did a long haul transporting an engine using a tire everything kept shifting. Driving 1500 miles on [censored] roads I want to have the load firmly in place. I tie to all 4 corners of the bed and have never had a problem I load my motors on one of those home built engine crates, holders, and put them up against the tailgate and use two little ratchet straps to hold the engine around the water pump to keep it from sliding forward on hard stops, works good, last a long time
