Re: To the People who use mechanical fans [Re: MoonshineMattK] #3068460
08/16/22 12:20 PM
08/16/22 12:20 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Originally Posted by MoonshineMattK
What kind of mechanical fan was it?
It was one of those stupid flex fans....And it flexed a little too far. It was not a factory fan on a clutch. Ran the weekend before with 6 passes on it and no issues.
Re: To the People who use mechanical fans [Re: Dragula] #3068480
08/16/22 01:01 PM
08/16/22 01:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think the tracks realize that if they started asking the people with late model cars to drain coolant that they would quickly run that revenue stream off. That group is also the least likely to put coolant on the track, at least from what I have seen.
68 Barracuda Formula S 340
Re: To the People who use mechanical fans [Re: Dragula] #3068502
08/16/22 01:59 PM
08/16/22 01:59 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Re: To the People who use mechanical fans [Re: Bad340fish] #3068504
08/16/22 02:03 PM
08/16/22 02:03 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
We have WILD temperature swings here in the heartland. It can be 75 degrees and sunny one day and 30 below the next. If the late model cars can run antifreeze then so will I!
'63 Dodge 330
11.19 @ 121 mph
Re: To the People who use mechanical fans [Re: GY3] #3068516
08/16/22 02:17 PM
08/16/22 02:17 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I get what you are saying, but people like you and I are way more likely to kick parts and coolant on the ground than the guy that is racing his hellcat or mustang or whatever. The late model guys are more likely to leave gear oil and driveshafts on the track.
